Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Tennessee Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Tennessee Chapter Join Chapter Leader: Neal 97 250
  #1 (permalink)
Old 01-18-2010, 09:21 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Garage is empty, add now
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
Jan. 23rd HEAD COUNT THREAD
We had a head count started awhile back in another thread. It got side tracked so here it is again.
Below is what the last post was so please check it to see if you are on it. I removed Ziggy. because I remeber he said he can't make it.
To add your name just copy the list and paste in your reply then add your name.
1. Jdecker88 - JD
2. Neal97F250 - Neal
3. Crum71 - Scott
4. 1999Superdutystroke - Ray
5. Torkum - Tim
6. Hucka1a REQUIRED - Huck
7. Harleymsn - Joe
8. Nflfreak43 ?? - Chris
9. 97 PSD - Ben
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
<!-- / message --><!-- sig -->
__________________
97 F250 Rosewood Stage II.75's, DP Tuner Live Tuned, Modded H2E, Terminated HPOS, Comp 910's, ARP studs, Swamps Pushrods, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch, RSK, D60, SD 1 ton springs DRD INMATE # 40
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #2 (permalink)
Old 01-18-2010, 10:54 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
If all goes well, I should be there.
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
__________________
'06 6.0L Turbo Diesel King Ranch DRW
2010 Platinum F-150
  #3 (permalink)
Old 01-18-2010, 12:49 PM
macgiobuin's Avatar
macgiobuin macgiobuin is offline
1966 Ford F-100
macgiobuin has a great reputation on FTE.macgiobuin has a great reputation on FTE.macgiobuin has a great reputation on FTE.macgiobuin has a great reputation on FTE.
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
11. macgiobuin - Roger
12.
13.
14.
15.
16.
17.
18.
19.
20.
  #4 (permalink)
Old 01-18-2010, 07:28 PM
jdecker88's Avatar
jdecker88 jdecker88 is offline
jdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to behold
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
12. Miranda diesel73junkie
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
16. Chris GoFastPadre
17. flyfishjeep
18. TopGun Customzs 5+
19. Ted Russell Ford 3+
20.
__________________
Justin (JD)
2000 F-250 CC SB 4x4
Roadside Help NetworkDP-Tuner Guzzle's Truck Site
Pete's Custom Filter Covers Riffraff Diesel Performance
Quote:
Originally Posted by megawatt00 View Post
Kinda tough to embrace the dark side when your an electrician.
  #5 (permalink)
Old 01-18-2010, 07:40 PM
tex25025's Avatar
OOO, were we supposed to put "+"s in there as well?
__________________
2010 Platinum F-150
  #6 (permalink)
Old 01-18-2010, 10:04 PM
1999SuperDutyStroke's Avatar
1999SuperDutyStroke 1999SuperDutyStroke is offline
1999SuperDutyStroke is gaining momentum as a positive member of FTE.
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
20. '99SDStroke's Wife - Amanda
__________________
Ray(LockDown)
~PAA #89~ETAPS Member~Late 1999 F-250~SuperDuty Shortbed Stroke~DP Tuner~6" Mitre Cut Stacks~TuggerKit~IssPro Gauges~DIY Intake~Leveling Shackles~ 35x12.50x16.5Coming Soon
  #7 (permalink)
Old 01-19-2010, 06:27 AM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 is gaining momentum as a positive member of FTE.nflfreak43 is gaining momentum as a positive member of FTE.
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
21. FordGirl88- Chris(nflfreak43's Fiance)
__________________
92 Flareside 165,000 miles
5.0 .030 overbore, Trick Flow Track Heat Heads, Comp Cam XE-264HR, 1.72 Scorpion Roller Rockers, Pacesetter Headers
Built By Twice Blown Racing Lebanon, TN 615-944-5650 @ 164,460 miles
AOD Rebuilt/Upgraded @ 159,450 miles
  #8 (permalink)
Old 01-19-2010, 07:22 AM
TNScrambler's Avatar
TNScrambler TNScrambler is offline
TNScrambler is starting off with a positive reputation.
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
22. TNScrambler - Justin
__________________
1996 F250 Crew Cab Short Bed 4x4.... D60, Hard Knox RSK with SD front and rear springs, 6637, 3in. downpipe, 4in. exhaust, E40D (ZF-6speed coming soon), '07 SD Lariat Seats, 140v IDM, hydroboost brakes, 38 gallon rear tank, and 251k +
www.efienginesupply.com
  #9 (permalink)
Old 01-19-2010, 07:40 AM
jdecker88's Avatar
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
23. John Cobb Cobbs Diesel Performance +1
24. Andrew Ward strokeless (cummins conversion)
25. James siloped
__________________
Justin (JD)
  #10 (permalink)
Old 01-19-2010, 06:37 PM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
1. Jdecker88 - JD
3. Crum71 - Scott
5. Torkum - Tim + Mrs. Torkum [Kim]
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
25. James siloped
Added Mrs. torkum
__________________
2003 SUPERCREW 4X4
www.TrueBlueTrucks.com
  #11 (permalink)
Old 01-19-2010, 07:41 PM
American Air-1's Avatar
American Air-1 American Air-1 is offline
2000 Ford F-350
My Garage
American Air-1 is gaining momentum as a positive member of FTE.
1. Jdecker88 - JD
3. Crum71 - Scott
7. Harleymsn - Joe
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
25. James siloped
26. American Air-1= Eddie
__________________
2000 F350SD, 7.3 PSD, AT, LWB CC, centurion conv., Bully-Dog 5 inch exhaust, DP Tuner, DieselSite ext. tranny filter, leather seats, DVD player, 6in. susp. lift, foil delete mod, daytime h/l delete mod, K&N air filter, Mag-Hytec rear cover. Check out our Air Suspension Parts and Coil Spring Conversion Kits: http://www.americanairsuspension.com
  #12 (permalink)
Old 01-19-2010, 11:59 PM
harleymsn's Avatar
harleymsn harleymsn is online now
1950 Ford F-5 Stake truck
harleymsn is gaining momentum as a positive member of FTE.harleymsn is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by American Air-1 View Post
1. Jdecker88 - JD
3. Crum71 - Scott
7. Harleymsn - Joe +(Debbie)
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
25. James siloped
added the Mrs.
__________________
Joe
1950 F5 Flatbed Flathead 8, 1946 Mercury Coupe (early 50's stock car) w/'50 8BA, 2001 F250 XLT 4x4 V10
http://onpitroad.smugmug.com/Ford-Tr...5323&k=GKMhh8n
  #13 (permalink)
Old 01-20-2010, 07:14 AM
1. Jdecker88 - JD
3. Crum71 - Scott
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
25. James siloped
27. Hard Knox Fab Works - Brett and maybe his wife?
Brett is doing custom fab for pretty much anything, but he does have a lifted superduty with his own custom built bumper, he also builds custom bumpers for the OBS trucks, said he would bring a few out to show off.
Justin
__________________
  #14 (permalink)
Old 01-20-2010, 08:16 AM
jdecker88's Avatar
1. Jdecker88 - JD
3. Crum71 - Scott
9. 97 PSD - Ben
10. tex25025 - Evan
13. HarleyF250Guy
14. Exelr8
15. 1badpsd ?
17. flyfishjeep
24. Andrew Ward strokeless (cummins conversion)+3
25. James siloped
Great to here Justin he will have some interested people for sure.
__________________
Justin (JD)
  #15 (permalink)
Old 01-20-2010, 06:27 PM
hucka1a's Avatar
hucka1a hucka1a is offline
hucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to all
When did my user name get changed to Hucka1a REQUIRED
__________________
Huck
Early 99 F250 with parts from Clay, Scott, Roland, Cory, JD, Pete, Christian, Neal, Jim. You could say "Built by Ford, Modded by the Brotherhood"...
Tags
clarksville, company, fordgirl88, harleyf250guy, mortgage, powered, raptor, tn, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
