Big deal or not? Rear diff seal leak
My truck is at the dealer now. I noticed oil all over my drive and noticed that the rear differential is leaking where the drive shaft comes in. The fluid looks like its been slung around under there. Is this a quick fix? I have no idea how long its been leaking. What damage could result? My truck has 52,000 miles on it, so this should be under the pwr train warranty shouldn't it?
Do you do alot of heaving towing? It is probably you rear pinion seal leaking. Unfortunatly, i do not believe it will fall under the powertrain warranty. If I understand correctly powertrain is from motor to trans and stops there. The rear diff and related parts fall under normal matinence, but you never know dealers can get creative to help you get covered.
Originally Posted by 69cj
Actually it's the motor only covered by the 5 yr/ 100,000 warranty.
Originally Posted by 2008 New Vehicle Limited Warranty
Rear-Wheel Drive:
axle shafts, bearings (front and rear), center support bearing, drive axle
housing (including all internal parts), drive shaft, propeller shafts, retainers,
supports, seals and gaskets, universal and constant velocity joints.
should be covered, yes it can be a big deal if you have lost quite a bit of fluid, but I bet not.
Pinion seal is most likely the cause. On that note I had one go bad, twice. Only got fixed when I insisted that the yoke is the cause.
Yoke had a groove worn into it and was leaking.
Not on my current truck but my 06 did this.
Thanks for the responses. When the first service dept person called me they said the truck was ready and it was $218. After reading the last couple of posts, I called back and mentioned that it should be under warranty. Five minutes on hold later, the young lady came back and told me that, yes, it was covered under warrany.
thanks again y'all.
thanks again y'all.
Spades
10-07-2016 09:47 AM
67FEranger
05-03-2010 09:21 AM
