Front inner axle seal replacement - Ford Truck Enthusiasts Forums
Old 01-17-2010, 06:26 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
Here are some pictures of the seals.The passenger side was leaking but I changed both sides.Not too bad besides trying to get the damn seals in straight.Had to modify my homemade seal tool toooooo many times.
With the help of Jason's(mechelement) great advise it went pretty well besides the seeal installation.I covered the carrier in ice after I got it out.Went right back in.
Old 01-17-2010, 07:47 PM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
Good job!
I'm going to have to do mine when things get warmer. My truck don't fit in the garage and there is still 6" of snow out here.
Old 01-17-2010, 07:53 PM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Quote:
Originally Posted by HD Rider View Post
Good job!
That could be to your advantage. Put the carrier in a plastic bag and pack it in the snow. j/k
Good job, Barry. Nice pics. Tried to rep you, but you know how it is.
Old 01-17-2010, 07:56 PM
riverrat41's Avatar
It is not a terrible job.You must get the new seals(2c3z-3254-aa)lined up straight and go easy.I am going to find the REAL set tool for putting those in.I just made my own and had to modify it too many times....Good luck
Old 01-17-2010, 08:03 PM
mueckster's Avatar
One can be made that will easily do the job with a couple of the right sized plates, nuts, and a piece of all thread. Picture of the Ford tool to follow.
Old 01-17-2010, 08:06 PM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Glad to hear it went overly well!
Old 01-17-2010, 08:08 PM
riverrat41's Avatar
That is exactly what I built but I did not have the correct size plates.I will be interested to see the Ford tool they mentioned in the manual I have.They did not have a picture.I am going to get me an assortment of those plates as well.They can be used for several different things.
Old 01-17-2010, 08:10 PM
riverrat41's Avatar
Quote:
Jason,I really appreciate your help on this.It went just like you explained with the carrier.The new seals were a battle but it worked out..Thanks again
Old 01-17-2010, 08:12 PM
mueckster's Avatar
Name:  Seal Installing Tool.gif
Size:  7.2 KB I will make one similar to this when the time comes to install the seals myself. It will push them straight into the housing.
Here is the text from my Ford dvd manual: "Place the axle shaft oil seals onto the tool, and position the assembly into the differential housing. Lengthen the tool as necessary until both seals start evenly in the axle tubes. Continue to lengthen the tool until both step plates bottom out against the housing."
Sounds simple, doesn't it. lol
Old 01-18-2010, 07:13 AM
HD Rider's Avatar
Does anyone have a part number for the tool?
Old 01-18-2010, 07:18 AM
riverrat41's Avatar
The manual says....Spreader bar...205-428...That is out of the Ford Manual
Old 01-18-2010, 08:39 AM
mueckster's Avatar
For model 50 axles, use special tools 205-428, 205-425 (LH), and 205-424 (RH) to install the axle shaft oil seals.
For model 60 axles, use special tools 205-428, 205-427 (LH), and 205-426 (RH) to install the axle shaft oil seals
From my manual. 205-424,425,426,427 are the stepped plates for the seals. 205-428 is the threaded bar.
Old 01-19-2010, 03:35 PM
HD Rider's Avatar
Thanks Roland
I wonder if those are Ford numbers or an OTC number.
Old 01-19-2010, 11:45 PM
mueckster's Avatar
OTC... Looks like each part number sells for about $100+ each.
Looks like I will be fabbing something when the need comes around.
Old 01-19-2010, 11:56 PM
Keep your eyes peeled on CL and you can run across a nice seal installation and puller kit. I found a Snap-On kit the other day for $150 OBO. I didn't inquire, but see stuff like that all the time on CL here.
Doesn't a Dana 50 have the seals on the outside of the diff?
After 3 years here is a quick breakdown of my progress. Holehawgg 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 05-05-2014 11:00 PM
Mid Fifty & pics theodore/teddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-15-2013 03:28 PM
I fought the Oak and the Oak Won 80351 Maryland Chapter 4 02-27-2011 07:44 AM
My Harem Zip British Columbia 13 02-18-2010 11:50 PM
Tags
2000, 205, 350, 428, 44, axle, f250, ford, front, otc, replace, replacement, seal, seals, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
