94 F250 slave cylinder change - Ford Truck Enthusiasts Forums
Old 01-17-2010, 01:37 PM
94F250XL 94F250XL is offline
94F250XL is starting off with a positive reputation.
Hi when i bought my 94 F250 in october i knew it need a slave and mastercylinder in the clutch, i bought the parts but i do not knoqw how to change and remove the cylinder(slave and Master) this is my 1rst truck and i am mechanically inclined to a certain degree i know very little about transmissions in truck( in a tractor i could fix it)
so where can i find the steps todo this change over with my dad???? thanks any help is GREATLY appreciated.
Nick- 94F250XL
here it is
p.s. i do have a bed ofr it it just isnt on!
Old 01-17-2010, 02:06 PM
88n94 88n94 is offline
88n94 is gaining momentum as a positive member of FTE.
Which engine do you have? Unless it's the 460 you would have an internal slave cylinder and have to remove the transmission to replace the slave cylinder.
Old 01-17-2010, 02:28 PM
5.0 302 5spd
Old 01-17-2010, 08:36 PM
anyone????????? i need to get this done
Old 01-17-2010, 08:56 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
the clutch master cylinder is fairly easy to knock out. disconnect the plunger from the clutch pedal from within the cab( it just pry's off) then drive the roll pin out at the bottom of the clutch resevior under the hood. carefully pull out the line. this will drain out the brake fluid that is in your resevior. then remove the two bolts that connect the master to the firewall of the truck. carefully pull the old master out of the firewall and everything will come out. next take the electrical sending unit off of the old clutch resevior. on the new master insert the plunger rod into the back of the master until you hear it click(lock) into place. then, transfer the sending unit over to the new resevior. install new resevior to firewall, and attach plunger to the back of the clutch pedal once again. plug in electrical clutch unit back to plug. put new o ring on line and push up into bottom of resevior. make sure it is al the way up and carefully drive in the new roll pin. this will lock the new line into place. fill with fluid. thats about it for the master.
for the slave. disconnect battery. remove shifter boot and shifter on both trans, and transfer case(if applicable) . drain fluid out of trans. case and transmition. remove drive shafts. disconnect and remove starter. disconnect clutch line going into transmition(you will need a special tool for this;comes in a clutch kit) place jack under trans and support. remove trans mount and trans crossmember. remove all bell housing bolts. carefully slide trans back and lower down to ground. inside bellhousing you will see the slave. remove the two 10 or 12 mm bolts(i beleive thats the size.....) and remove old slave. install new slave and tighten down. wipe down inside of bell housing if it is covered with brake fluid from the slave. then your done with that, and install is reverse of removal. after everything is installed back, fill with fluid, and bleed clutch system.
please keep in mind that i did this on my 95 which had the 4.9 straight six, and i did not have to remove parts of the exhaust, or the floor pan around the shifter under the carpet.
anyone else if i have missed anything please chime in.....
Old 01-17-2010, 09:08 PM
thank you very much mines a 5.0
Old 01-17-2010, 09:44 PM
ok. theres a good chance that you will have to remove part of your exhaust....hope it helps man...i just did my slave, clutch, and rear main earlier today and the master last week..
Old 01-18-2010, 03:54 PM
ok thanks man now i got a job for myself!
Old 04-16-2016, 02:30 AM
max sunrise max sunrise is offline
max sunrise is starting off with a positive reputation.
no clutch
i have a 93, f-250 4x4,up to now the clutch worked fine.The truck sat for a couple months and when i went to start it there was no clutch, the pedal goes to the floor and nothing, stays there. What is the cause?
Old 04-16-2016, 05:35 AM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Wow, bringing zombie threads back to life...
This sounds silly, but have you checked clutch fluid reservoir?
Old 04-17-2016, 11:47 AM
93, f-250 clutch issues
yes, i cheched the levels, they are good. when i pump the clutch pedal by hand fluid comes out of the reservoir cap
Clutch/Master/Slave question; early zf5 in a 94.5 DRW... naga77777 1994.5 - 1997 7.3L Power Stroke Diesel 11 01-20-2016 09:43 AM
I NEED ADVICE Lost cause Clutch, Transmission, Differential, Axle & Transfer Case 15 10-27-2015 08:50 PM
Clutch External slave to Internal slave conversion aikensj 1987 - 1996 F150 & Larger F-Series Trucks 11 08-09-2015 02:37 PM
Bad slave cyl rangergirl94 1987 - 1996 F150 & Larger F-Series Trucks 15 03-16-2012 09:22 PM
1999 F250 bleeder on Clutch Slave Assembly trevwilliams 1999 to 2016 Super Duty 3 04-20-2009 08:35 AM
Tags
1996, 94, change, changing, cylinder, disconnect, f150, f250, f350, ford, internal, location, removal, replace, slave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
