Does anyone know the symptoms of a bad air charge sensor?Will it definitely throw a check engine light?...I am trying to figure if I have one problem or two...as stated in a recent post I lose all my fuel pressure when the pump disengages,but I am also having alot of rich,flooding problems....
A bad sensor will throw a code. Loss of fuel pressure and running rich indicates a fuel supply problem, and since you have already changed the FPR I'd suspect a stuck injector. This should be relatively easy to find just look for the wet sparkplug.
