100,000 mile service?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-16-2010, 10:20 PM
roverjoe's Avatar
roverjoe roverjoe is offline
roverjoe is starting off with a positive reputation.
Well my 2002 F250 5.4 will soon be approaching 100,000 miles. The truck runs great & looks great. I want to keep it that way.
Any "must do" maintenance which should be competed at 100K?
Here is my tentative plan:
- Change oil. I've been running Mobil 1 5-20 for about 40,000 miles.
- Flush and change coolant.
- Front brakes (I'm going to need them).
- Change swaybar bushings to poly bushings.
- A good wash and waxing.
- Leather conditioner on the interior, scrub carpets.
Any other items I should put on my list please speak up!
Thanks
Old 01-16-2010, 10:39 PM
jac08f250's Avatar
jac08f250 jac08f250 is offline
jac08f250 is starting off with a positive reputation.
spark plugs and I don't know how often you do it but tranny fluid flush.
Old 01-16-2010, 10:55 PM
Smokey7.3 Smokey7.3 is offline
Smokey7.3 is starting off with a positive reputation.
dont forget to replace the spark plug boots on the coils and only torque your plugs to 14 ft lbs it doesnt feel like much but that is the ford spec improper plug torque can cause your spak plugs to blow out of the head
Old 01-16-2010, 11:28 PM
jac08f250's Avatar
Belt. And of course check the muffler bearings and check your blinker fluid levels.
Old 01-17-2010, 05:28 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Coolant will need to be flushed as well. If you have a 4x4 then do the needle bearing maintance.
Old 01-17-2010, 06:52 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Changing your brake fluid will also be a good thing.
(No, seriously)
The wear particles in the master cylinder contaminates the fluid. Flushing this grit out will extend the life of your master cylinder, hoses, hard lines and calipers.
100,000 gdiehl 6.7L Power Stroke Diesel 9 11-13-2016 09:15 PM
Another 100K Super Duty FordmanNJ 1999 to 2016 Super Duty 6 05-09-2016 03:23 PM
100,000 mile maintenance? GRB1 1997-2006 Expedition & Navigator 0 07-18-2013 07:01 PM
About how long Gun-Driver Bio-diesel, Propane & Alternative Diesel Engine Fuels 9 04-22-2007 07:21 AM
100,000 mile service expe00 1997-2006 Expedition & Navigator 3 09-05-2003 10:39 PM
Tags
100000, 100k, 150, 1999, 2005, check, cost, f150, f250, ford, maintanence, mile, service, truck, typical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
