Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-11-1999, 12:43 AM
Pup Pup is offline
Pup is starting off with a positive reputation.
Overheating at Idle
I have a problem with my 72 F100 360 overheating when at an idle. Ive tried running without a thermostat and with one. I just recently flushed the cooling system it has a flex fan and a factory fan schroud. when it idles for any amount of time it gets up over 230deg and when I give it a little gas the temp dropps. Any help would be appreciated.
Pup
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-11-1999, 02:53 AM
rollingthunder is starting off with a positive reputation.
Overheating at Idle
double check your radiator juice, it might be that simple, if not, you might be changeing your water pump. Do you have hot air coming out of the heater at idle, and do you have cooler air when then motor temp dropps when driving? It has happened to me at times, it was low on coolant.
  #3 (permalink)
Old 12-11-1999, 07:49 AM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
Overheating at Idle
pup, Could you tell us a little more is it...
a new install
how long does it take to acheive this
have you checked your fluid mix I use 50/50
hows the timimg, that can make it hot
have you changed the fan
There is not enough air flow to handle the current set up.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 12-11-1999, 07:11 PM
TomC is starting off with a positive reputation.
Overheating at Idle
Check first as to whether you have much rust in the cooling system. The water jackets at the base of the cylinders build up lots of rusty sludge and can cause a problem like you have. If rust is present, knock out the freeze plugs and flush our as much as you can. then you have to use something to dig out the hard stuff at the bottom of the water jackets. Replace the freeze plugs and flush the cooling system with the two part rust remover. Use distilled or rain water to refill and put a coolant recovery system in to prevent futher clogs.
Hope this is of some help.
  #5 (permalink)
Old 12-11-1999, 11:34 PM
Trail_Rider is starting off with a positive reputation.
Overheating at Idle
__________________
Trail Rider
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
