Truck not shifting correctly, speedometer not working
#31
Hi all, I know that this is a old thread, but just wanted to thank you all for this awesome forum, my '99 250 xlt cc 7,3 just got the symtomes described here, abs light on, speedometer not working and O/D light flashing.. gonna order myself a new VVS today
BTW does anyone have the part number or know of an store who deliver to norway??
Again thanks alot
Again thanks alot
#33
#34
Second Id recommend you to began a NEW THREAD and link this one there. Anyway maybe the fuse is going south or a bad connection.
Good luck.
#35
#38
#40
Interior lights work fine. The wiring harness seems fine. I pulled every one of the fuses which were all fine. I could try to clean the terminals on the sensor harness again. Any suggestions for what to use? I would assume there is another magnet in the diff but I feel like I may have bigger problems if I have a piece of metal floating around in the rear diff.
#41
#43
#45
Did you get a mptorcraft sensor?
How did you chheck wiring?
if you are confident the wiring is good i would pull it.
any idea when the diff was serviced last.may not be a bad idea anyway to service it annd take a look while you are in there.
especially for a crack.its a press fit on the carrier
