Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-16-2010, 02:58 PM
08 Navigator 08 Navigator is offline
Garage is empty, add now
08 Navigator is starting off with a positive reputation.
Install Rear Seat DVD?
Has anyone ever installed a rear seat DVD player in a truck that came from the factory without one? I bought a player and cable on line for a hundred bucks, and now I'm wondering if it is more trouble than it is worth to install.
I've got a 2008 Navigator with an OEM navigation system.
Any thoughts? Thanks.
  #2 (permalink)
Old 01-16-2010, 10:10 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
Are you talking about an OEM system or an aftermarket system?
__________________
2007 Expedition Limited White Sand
  #3 (permalink)
Old 01-16-2010, 11:11 PM
It's an OEM rear DVD player, one of those roof mount units. It's got a cable that plugs into the factory harness somewhere in the left rear kick panel.
I haven't looked under the headliner, so I don't know if it needs some sort of bracket or not.
I was hoping someone on this board had done this upgrade. The parts are cheap on eBay,
  #4 (permalink)
Old 01-17-2010, 10:45 PM
I am not sure if there is a bracket or how it is mounted but that should not be a problem either way. Check with the dealer and get an exploded view of how it is mounted. The cable is usually the hardest part to locate unless you buy it from the dealer$$ so you got lucky.
Another thing to consider is that you will have to send your navigation unit off to get reprogrammed for the dvd control (so you can play,pause, etc the dvd from the nav unit) That runs about $90.
__________________
Tags
2009, accessories, back, dvd, expedition, f150, ford, install, installed, raptor, rear, rearseat, seat, seats, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
