Where to put oil temperature sender
Old 01-21-2010, 10:59 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
I like the idea of dual sensors with a switch mounted in-line. Reps sent Brandon!
Old 01-21-2010, 11:01 AM
kirkharrod's Avatar
kirkharrod
kirkharrod is offline
Originally Posted by bdrummonds
You will literally be suprised at how long it takes to warm 4 gallons of oil to 180*+.
Yep and the coolant temperature decreases faster than the oil temp also.
Old 01-21-2010, 11:10 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
HPOP T for oil temp.
While it looks good, a oil temp sender should be in the res if you do it like that, if not it will take a long time to warm up because the oil in that T does not get transfered out of the T, it is only under pressure and warms thru convexction. Not knocking it, but without fluid transfer your not getting the correct temp reading.
For what its worth.
Old 01-22-2010, 07:38 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
Originally Posted by maevans
See where the brass colored plug is in the oil filter housing, that's where I have seen a few install a sensor to read the oil temp. and I plan on doing the same as soon as it warms up outside. ( Thanks Cody for the pic )
Quick question...
Is the brass plug 1/8 NPT, if not can someone provide the size?
Thanks A Million!
Old 01-22-2010, 08:48 AM
Ponyboychris
Hit it!
For what its worth.
So would it be better to mount it in the filter housing where the brass plug is?
Old 01-22-2010, 10:51 AM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Originally Posted by 03_PSD
Quick question...
Thanks A Million!
Yes, its 1/8" NPT
Old 01-22-2010, 10:55 AM
clux's Avatar
clux
clux is offline
Aren't you getting the temperature of the oil straight out of the oil cooler on the filter port?
Don't know that location provides very beneficial information either.
Old 01-22-2010, 10:59 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
No better or worse, it just needs to be in the flow...
That location is just before it goes INTO the cooler.
Old 01-22-2010, 11:04 AM
clux's Avatar
clux
clux is offline
Not unless you reverse the flow of the oil through your engine somehow.
Old 01-22-2010, 11:28 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Well it runs 10-15* higher then the HPO res so... I dont know... I have seen that PDF before and thought it strange.
Old 01-22-2010, 11:33 AM
clux's Avatar
clux
clux is offline
Ok, I'll bite, what's strange about that PDF?
Old 01-22-2010, 11:35 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
That the oil temps were higher then water temps when at that location... Not looking for a fight...
  #28
Old 01-22-2010, 11:38 AM
clux's Avatar
clux
clux is offline
It doesn't matter how good of a cooler you have, it's it's pretty simple physics that it's not going to take the oil temperature all the way down to the water temperature.
  #29
Old 01-22-2010, 11:49 AM
Ponyboychris
Hit it!
What is the normal temp range for oil?
  #30
Old 01-23-2010, 12:23 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
Once up to operating temp it depends on the load... I see anywhere from 190 to 220...
Quick Reply: Where to put oil temperature sender
