PATS Thread - Program Your Own Keys & Other Useful PATS Info - Ford Truck Enthusiasts Forums
Old 01-16-2010, 05:33 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
The following will be covered:
1. PATS System
2. Purchase a PATS key for "Cheap"
3. Programming a PATS Key
4. Programming a Remote/Fob/Clicker
5. Programming the Door Keypad
6. Using a Fusion Key Instead
1. PATS System
PATS stands for "Passive Anti-Theft Security". It is Fords answer to car theft.
Inside each key, there is a little RFID chip. When properly programmed, your trucks PCM reads and recognizes the RFID inside the key.
Without the proper RFID signal, the ignition system WILL NOT WORK. Motor won't even turn over...basically makes the vehicle one big paperweight. This makes it alot harder to steal a late-model Ford.
2. Purchasing a PATS Key
You have 2 options here.
2a) Buy one from the Dealership. Can run $50+ quite easily
2b) eBay! I have bought many many PATS keys from $5-10 shipped over the years. They are plentiful.
There are 2 ways to program a PATS key.
3a) You have 2 PATS keys that already are programmed = FREEBIE!
3b) You only have 1 PATS key programmed = Costly
Unfortunately, you must visit the Dealership, or a properly equipped Locksmith. They will have to connect a special tool to the PCM and perform the key programming for you. Roughly costs $40-50 (1/2 hour labor) for this service.
No requirements here.
Simply have all the clickers with you in the truck and go to town. Extremely easy. If you don't have a clicker, eBay is your friend as usual
Again, super easy to perform...if you have the OEM Factory code. If not, you can visit the Dealership and drop some $$$...or look on the rear wall of the cab. There is a lock control module with the code printed on a white sticker. here is a link.
"Easy" way to Remove your backseat
So if you are like me, the key + clicker can be somewhat cumbersome.
luckily, the Ford Fusion key/clicker will work with our trucks. It is a combo unit that uses the same key & clicker frequencies.
I love the one I have for my Expy & Mustang.
To use one, follow the seperate programming instructions above for the key and clicker. You have to program each portion induvidually.
As for purchasing one...eBay!!! Notice a trend?
These keys are not quite as cheap as a normal PATS key however. But the going rate seems to be about $30 roughly. To me, highly worth it.
You go from this:
To this:
Hope this clears things up. If you have any questions, please ask.
Old 01-16-2010, 07:37 AM
Flying_Dutchman's Avatar
Flying_Dutchman Flying_Dutchman is offline
Flying_Dutchman has a good reputation on FTE.Flying_Dutchman has a good reputation on FTE.
Good thread, Ill have to give this a try.
Old 01-16-2010, 09:55 PM
30coupe 30coupe is offline
30coupe is starting off with a positive reputation.
Great stuff Tylus! Thanks a bunch! I need to do the door keypad thing, so this will really help.
Old 01-16-2010, 10:19 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Well presented instructions.
Sticky Time!
I've posted this same info several times over the years.
Put it in the Articles.
I tried to rep you, But you know how it is.
I've got to spread the loving around first.
Old 01-17-2010, 10:03 AM
pohlmeyr pohlmeyr is offline
pohlmeyr is starting off with a positive reputation.
do you have a trusted seller on ebay you use?
Old 01-17-2010, 01:28 PM
shorebird's Avatar
Old 01-17-2010, 02:56 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
I've found the vendor "mykeyless-1" on ebay to be reliable, I've also used "keys_star" with great results. Both include instructions as described in the listings. There are others like the one shorebird mentioned above.
Just look up their records if you question their trustworthyness.
Also, I use PayPal, beside protecting your card, it offers some degree of "buyer protection".
Old 01-25-2010, 06:53 PM
Hummah Zach's Avatar
Hummah Zach Hummah Zach is offline
Hummah Zach is starting off with a positive reputation.
The RFID thing in the key is really interesting, does my 04 have this? Is the chip in the key itself or the fob?
Old 01-25-2010, 08:42 PM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
Quote:
the chip is in the key and yes that is the way all fords work that have pats
Old 01-25-2010, 09:35 PM
thats awesome, another reason to be proud to own a Ford
Old 01-26-2010, 07:25 AM
Gearbanger 101's Avatar
Gearbanger 101 Gearbanger 101 is offline
Gearbanger 101 is gaining momentum as a positive member of FTE.Gearbanger 101 is gaining momentum as a positive member of FTE.
Nice write up
....now, tell me how to program a factory key fob, to work with my aftermarket car starter and we're all set.
Old 01-27-2010, 12:59 AM
Tylus's Avatar
sorry, I had forgotten about this. glad to see the other guys answered the questions
Quote:
I've bought once from a seller that Bridge mentioned...but mostly I just find the best price.
and then I read their feedback. 95% or better only for me...and if they aren't 99%, I read a few pages into their feedback and see why.
to be honest, most of the eBay keys are probably China knock-offs...but they work, and I've been using them for almost 10 yrs now without any issues. So IMO you probably should be too worried about it.
Old 01-27-2010, 11:02 AM
greenhornet410 greenhornet410 is offline
greenhornet410 is starting off with a positive reputation.
The Fusion Key will work with my 04 f150
Old 03-14-2010, 05:00 PM
jfaaborg jfaaborg is offline
jfaaborg is starting off with a positive reputation.
any key fob that will support two ford vehicles?
Old 03-14-2010, 07:46 PM
shorebird's Avatar
Quote:
Fobs can only be matched to one vehicle at a time.
You can take a fob from one vehicle and match it to another but it will no longer work for the previous vehicle until it is again matched it.
'86 Franken-250 Tylus 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-11-2017 07:03 PM
New Toy: Franken F-250 Tylus 1987 - 1996 F150 & Larger F-Series Trucks 7 01-03-2017 10:14 AM
Custom FX4 Dash Plaque/Emblem for 04-08 FX4 Tylus Ford Truck Parts for Sale 4 03-31-2016 05:03 AM
2005+ Style F-250 Grab Handle Installed in 2002 X Tylus Excursion - King of SUVs 15 03-17-2016 07:15 PM
It took long enough, but I finally got me one! Tylus Excursion - King of SUVs 31 06-11-2013 12:04 AM
Tags
04, 2001, 2006, expedition, f150, factroy, ford, key, keys, pats, program, programing, programming, remote, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
