PATS Thread - Program Your Own Keys & Other Useful PATS Info
The following will be covered:
Hope this clears things up. If you have any questions, please ask.
1. PATS System
2. Purchase a PATS key for "Cheap"
3. Programming a PATS Key
4. Programming a Remote/Fob/Clicker
5. Programming the Door Keypad
6. Using a Fusion Key Instead
1. PATS System
PATS stands for "Passive Anti-Theft Security". It is Fords answer to car theft.
Inside each key, there is a little RFID chip. When properly programmed, your trucks PCM reads and recognizes the RFID inside the key.
Without the proper RFID signal, the ignition system WILL NOT WORK. Motor won't even turn over...basically makes the vehicle one big paperweight. This makes it alot harder to steal a late-model Ford.
2. Purchasing a PATS Key
You have 2 options here.
2a) Buy one from the Dealership. Can run $50+ quite easily
2b) eBay! I have bought many many PATS keys from $5-10 shipped over the years. They are plentiful.
There are 2 ways to program a PATS key.
3a) You have 2 PATS keys that already are programmed = FREEBIE! 3b) You only have 1 PATS key programmed = Costly
Unfortunately, you must visit the Dealership, or a properly equipped Locksmith. They will have to connect a special tool to the PCM and perform the key programming for you. Roughly costs $40-50 (1/2 hour labor) for this service.
No requirements here.
Simply have all the clickers with you in the truck and go to town. Extremely easy. If you don't have a clicker, eBay is your friend as usual
Again, super easy to perform...if you have the OEM Factory code. If not, you can visit the Dealership and drop some $$$...or look on the rear wall of the cab. There is a lock control module with the code printed on a white sticker. here is a link.
So if you are like me, the key + clicker can be somewhat cumbersome.
luckily, the Ford Fusion key/clicker will work with our trucks. It is a combo unit that uses the same key & clicker frequencies.
I love the one I have for my Expy & Mustang.
To use one, follow the seperate programming instructions above for the key and clicker. You have to program each portion induvidually.
To this:
As for purchasing one...eBay!!! Notice a trend?
These keys are not quite as cheap as a normal PATS key however. But the going rate seems to be about $30 roughly. To me, highly worth it.
You go from this: These keys are not quite as cheap as a normal PATS key however. But the going rate seems to be about $30 roughly. To me, highly worth it.
To this:
These are sellers I have usedl.
Shop eBay Canada Store - KEYLESS REMOTE:: GMC Chevrolet, ASSORTED KEYLESS REMOTES
http://stores.ebay.com/transponderkeysforless
Keys for less is my Ford key source.
do you have a trusted seller on ebay you use?
Just look up their records if you question their trustworthyness.
Also, I use PayPal, beside protecting your card, it offers some degree of "buyer protection".
sorry, I had forgotten about this. glad to see the other guys answered the questions
I've bought once from a seller that Bridge mentioned...but mostly I just find the best price.
and then I read their feedback. 95% or better only for me...and if they aren't 99%, I read a few pages into their feedback and see why.
to be honest, most of the eBay keys are probably China knock-offs...but they work, and I've been using them for almost 10 yrs now without any issues. So IMO you probably should be too worried about it.
