Headlight Relay upgrade w/ extras How To
today i will be upgrading my headlight harness to 10gauge w/relays.
I will be using Philip's Night Guide 9007 bulbs.
NightGuide
I will also be modding the hi beam circuit. I will make the low beams come on with the high beams. I will use a diode so the current doesn't bleed back so i will have low beam, hi beam, and hi & low beam with fogs all the time. giving the ultimate light out put. My only concern will be the heat from the bulbs when low and hi are on. I have a blue LED switch to control the low/hi function.
Pics and diagram will be posted soon. I could also run daytime running lights off a relay switch by keyed current but i decided just to turn the light switch on instead. this mod will require no modification to the original harness. you will see with pics. fun fun fun
NightGuide
on
if you get the fog light mod done. pull your hi beam switch back to the flash and hold it there. you will be surprised at all the light. your fogs are low, the lowbeames are alittle higher and the hi beam is higher still. Its like a Huge spotlight. But time to get to work. I work slow so it might be around 9 or 10 befor I'm done. I like to make my mods look factory and done right.
on
searching
after doing a lot of research... they have kits for this, of course the brite box which will activate the low and highs together, with a fog light option is $110 for diesels, and upgraded harness and relays are $70 from gos.
so about $200 mod, if you want little work and clean install
we will have to wait on the DIY figures
FD$Acc
http://www.dieselsite.com/index.asp?...S&Category=320
FD$Acc
I did not know about this harness. well my harness and doing it my self cost around $40 so his harness would have been worth it. I recommend just buying his harness. I do have my low w/ hi on a switch and its plugged into the old light plug for the trigger. I used the old bulbs to put on the old harness. i just removed the bulb and filled it with rtv.
I also checked the voltage befor doing the mod at the bulb. I was only losing .5volt so it really wasn't worth it to do all the work. My switch has a diode on it so i could jump the hi and low beam wires together. Do not use a diode in the harness unless its just to turn on the relays. it will start on fire.
on
monster-4 are you saying the harness lights up low beam with the highs on, but not the highs with the lows on right? Also, does it upgrade the wires by useing relays and larger wire from the batt?
And lastly how much was this?
The pic is the same pic ths GOS uses. they want 79 just for the upgrade harness, then 129 for a brightbox to do the high/low mod. that would be almost 200 for what it sounds like you have. Odd thing to me is they show the exact same pic. So maybe i ma missing something.
curious what you paid, and how well it works.
Mine is wired to the battery with relays. According to the documentation and what I can see both low and high beams light up in the HI beam position and only the low beam in the normal position. I paid $74 for my harness but that was in 2007 so it looks like the cost went up a little.
I always thought you only need the BrightBox if you have DRL?
Harness attached to battery
Relays. One set of wires/relays goes to passenger bulb and the other set goes to drivers side.
Bulb end of harness on passenger side
on
