351w efi to replace 302 efi 1989 f150
Hi Guys
My Father and myself would like to upgrade our 1989 f150 from the original 302 efi to a 351w efi. Our hope is to find an 351 that will plug
into the existing harness and cause as few installation problems as possible. My question is does the computer have to be changed so
it doesn't think it's running the old 302? Our truck did come with the 351
option but we didn't expect to be towing a trailer and the 302 is a bit tired, is this swap going to be a real problem? We really need a stronger pulling truck and can't afford a new one. Any info you have would really help us out.
Thanks
Mike
Thanks
Mike
on
You need a complete 5.8 EFI motor and then it's a simple bolt-in with a 28oz flywheel/flexplate for whatever transmission you have. Do not change anything else besides the plug wiring order. The 5.8 should work pretty good after the computer has a chance to adapt, but if it doesn't come around finding a 5.8 computer for it shouldn't be too hard, there were lots of 5.8 trucks in the late '80's and early '90s that would make good donor candidates.
I suggest getting a 351 computer to go along with the engine. The fuel mapping for the 302 will not work very well with the 351. I ran a 351 computer on my 302 to test the computer and it ran like crap. As these other guys have said, just use the original 302 wiring harness - it will work with the 351 computer too.
Hi Guys
We where planning on pulling a car trailer and maybe a large camper (long term idea)
the truck is stock gearing I think 3.00:1 with aod trans, we wheren't planning on changing
the gears but maybe adding a better set of leaf springs. Does anyone know who would sell
a stock rebuilt 351w? All I can find are preformance engines.
Mike
Mike
Hi Guys
Mike
Mike
Your AOD trans will bolt up to the 351w but you are going to have to put in a few trans upgrades if you are using it behind a 351 and planning on towing. An external cooler and a shift kit are really going to help the trans last behind that motor.
And gears... there is no such thing as stock gearing, and the 3.00 ratio was only offered with the Ford 9" axle which your truck doesn't have. If you don't have at least 3.55 gears you are going to be very unhappy with the towing performance no matter what you do to the trans and engine.
Jasper sells rebuilt 351w's and I've heard good things about them. Also check into adding a cam and exhaust to the build, as the 351w is strangled by the factory exhaust and cam. It will really wake the motor up (at least that's what Paul says and he is the resident SBF expert )
Rebel 84
05-17-2015 07:06 AM
tweakerford
03-07-2015 04:52 PM
07f250diesel
07-10-2014 08:04 PM
James C
06-22-2014 10:31 AM
