replacement seat cushion? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-15-2010, 09:04 AM
99F-350CrewCab's Avatar
99F-350CrewCab 99F-350CrewCab is offline
99F-350CrewCab is gaining momentum as a positive member of FTE.99F-350CrewCab is gaining momentum as a positive member of FTE.
Has anyone seen a source for these or had any experience replacing them? I think the drivers seat in my truck is wearing out. The back left corner sits really low and I'm almost hitting the plastic trim around the seat. I feel like I'm falling out the door and wanted to see if I could firm that cushion up. Thanks.
Old 01-15-2010, 04:18 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Old 08-15-2011, 08:37 AM
dcf4x4's Avatar
dcf4x4 dcf4x4 is offline
dcf4x4 has a good reputation on FTE.dcf4x4 has a good reputation on FTE.
Kevin, did you ever find a cure? I'm in need of one myself.
You wouldn't happen to have a part number would you?
Old 08-15-2011, 10:48 AM
I haven't done anything about this, but I have seen a few threads about seat cushion replacement and it doesn't look too hard. PartsGuyEd has the replacement cushions I think.
Old 04-24-2014, 03:44 PM
Finally got around to replacing this and after 12 hours in the seat yesterday, I can say it made a good difference.
Brand New LH Front Seat Cushion Pad 1999 2007 F250 F350 F450 F550 Super Duty | eBay
Here's the seat cushion I ordered.
F81Z-25632A23-BA
That's the part number.
I didn't even have to remove the seat. I took off the cover on the left side of the seat where the power seat and recline controls are, and removed the two bolts that hold the rear of the seat to the bottom. Then I was able to just un clip and pull back the seat cover, take the old cushion out and put the new one in. Took me 30 min tops. The old one was split and deteriorating, the new one is much more supportive.
Seat Cushion Cover Source. krooser 1987 - 1996 F150 & Larger F-Series Trucks 5 03-27-2015 03:34 AM
seat/back foam cushions or new seats AppocAlexx Excursion - King of SUVs 12 03-03-2015 04:32 AM
'04 Seat cushion removal for heater replacement fordfool2 Explorer, Sport Trac, Mountaineer & Aviator 4 11-27-2010 07:43 PM
SuperCab Rear Cushion Removal Munkey 1999 to 2016 Super Duty 4 04-29-2008 11:57 PM
Crooked Leather Seat ???? 98SurplusExpy 1999 to 2016 Super Duty 2 12-31-2007 09:05 PM
Tags
1997, 350, cushion, cushions, f150, f250, f350, ford, replace, replacement, replacing, seat, seats, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
