Replacing side mirror cover
Hey Guys-
I've got an '06 XLT--
I'm wondering if the title to this thread is even possible.
I wrecked the plastic cover on my side mirror on a frigid night last week. The mirror did fold back as designed when it rubbed against the tree, but I think it was so cold that the plastic was brittle.
Anyhoo, the black plastic around the mirror is busted up, but the mirror itself and the adjusting mechanism is fine.
I need to make my mirror whole, but fear that the only way to do it is to replace the whole deal.
Any help?
Thanks-
Any help?
Thanks-
The mirror is a total replacement unit. You can do the replacement. It is rather easy. Snap off the cover on the inside and then unbolt the mirror. Unplug it and install the new one.
Here is a source ; Discount Auto Mirrors - 2006 Ford F-150
Alternitive is a chrome cover from; 2006 Ford F-150 XLT PART # MC67301 @ WheelsAndCaps.com
the mid-level mirror is actually 2 parts on 2004-2008 trucks, and 2007-2008 higher end trucks (Lariat, KR, FX4 Prem) have 3 parts.
so on your 2006, what exactly is broken?
the 04-06 mirrors split into 2 halves. a front piece that bolts to the main mirror assembly, and then the main mirror assembly itself.
if you are lucky, you only broke the front part, which is essentially a cover. if that is the case, you can remove the glass portion and simply unbolt the cover. it is 4 little hex nuts.
to remove the glass, push in the top portion until the bottom area is fully extended. then insert a thin flathead through the bottom and pry the mirror mount from the center holdy thingy. sorry for my lack of technical terms. but you'll see what I mean.
DO NOT JUST PULL ON THE MIRROR ITSELF!!! I did this and broke mine into 3 chunks. And then I had to use the method I described above.
but yeah, hopefully you only broke that front casing. if so, it's pretty cheap and easy to replace. below is a picture with the part I'm talking about outlined in green. the part of the moving joint that isn't outlined, and the internals are the main mirror assembly.
they were $7-15 to purchase when I was looking last year. Hope they are still so cheap
I found these instructions while web searching.
I can't imagine a better step by step illustration on how to remove the door panel on '06 through '08 F150s.
There are a lot of steps, but none of them look too difficult.
Remove Door Panels On A 2008 Ford F150 Pickup Truck
Where did you find the covers. I have looked everywhere and can only find the complete mirror as a unit.
And, if the plastic shell (the part that is broken on mine) can be replaced without taking off the interior door panel, that would save me lots of hassle--
majkthreads
1999 to 2016 Super Duty
19
06-01-2011 08:28 PM
