2002 ranger abs - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
2002 ranger abs
Old 01-14-2010, 12:14 PM
mattcomparato mattcomparato is offline
mattcomparato is starting off with a positive reputation.
2002 ranger abs
having a issue with abs light on dash coming on.brakes have all recently been changed and fluid is full.any thoughts on what could be?
Old 01-14-2010, 02:55 PM
Eaglefixer Eaglefixer is offline
Eaglefixer is starting off with a positive reputation.
was the ABS light on before the brakes were changed? If not then you may need to bleed the brake again and again. If the light was on before then you will need to take it the the Ford Dealer and have them put it on there tester. I Had a 93 Ranger that the ABS light came on and stayed on. Took it to the dealer and it was the ABS Control Valve
Old 01-15-2010, 03:42 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
Were the rotors replaced during brake work? Make sure they have the slotted trigger rings like the originals for the sensors to read. Also check the sensors to make sure in place and not dirty and have a good electrical connection. Does speedo act up along with abs light? Could be speed sensor in rear axle. Also I have read that the light for the passenger air bag shutoff switch can fail and trigger the light.
Old 01-15-2010, 02:22 PM
Areyouforcereal?'s Avatar
Areyouforcereal? Areyouforcereal? is offline
Areyouforcereal? is starting off with a positive reputation.
If it's a 4x4, check your front wheel bearings/hubs. When they fail it destroys the abs sensor and throws the light.
ABS light on Jaaaaaaackman 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-27-2016 12:34 PM
ABS light Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 11 10-07-2012 08:59 AM
Help pulling ABS codes? Beastlyforddude 1987 - 1996 F150 & Larger F-Series Trucks 11 02-16-2011 01:54 PM
Why AB/BC and BC chapters LaredoF350 Canadian National Chapter 1 02-20-2007 03:09 PM
1999 Ford Explorer Brake, ABS Problem nocal Brakes, Steering, Suspension, Tires, & Wheels 2 06-13-2004 06:48 PM
Tags
02, 2002, 2003, 33x1250, abs, codes, controller, ford, hubs, level, light, locations, ranger, read, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
