351w in a 73-79 f100 headers issue - Ford Truck Enthusiasts Forums
Old 01-13-2010, 11:10 PM
77f100guy's Avatar
77f100guy 77f100guy is offline
77f100guy is starting off with a positive reputation.
I am looking for someone who has already been down this route. Someone with a 73-79 F100 with a 351w, what kind of headers are you using?
Old 01-13-2010, 11:27 PM
77f100guy's Avatar
Also is it possible that I could just have some custom made and around what would something like that cost?
Also what are header flanges? they look as though they bolt straight to the head, but are cut extremely short, is this an adapter and for what type or problem would this work?
Old 01-14-2010, 08:25 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
long tubes are out of the equation,it will have to be shorties unless things have changed since I had a 78 that i swapped a 351w in a few years back,no one makes long tubes for this truck/engine combo. I used MAC mustang shorty headers that I got off of ebay. the driver's side fit like it was made for the truck,the passenger's side had to have some tricky bends done to clear the frame,but it is possible. you might try to contact a user on here by the name loudfords,he has some pictures of the shorties on his truck.
Old 01-14-2010, 11:13 AM
loudfords's Avatar
loudfords loudfords is offline
loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.loudfords has a great reputation on FTE.
Yep, I used Mustang shorties on mine. There are several users here running Summit long-tubes for a 302 that fit with minor tweaking. If I had to do it again, that's probably what I would use.
Old 01-17-2010, 12:39 AM
ozblitz ozblitz is offline
ozblitz is starting off with a positive reputation.
I made this swap before (same truck) and I bought SB shorty's from FORD SVO. 10 years later 351w blew and now I have the same shorty's on a 5.0 EFI
Old 01-17-2010, 10:16 AM
77f100guy's Avatar
where can i find these ozblitz
Old 01-17-2010, 01:36 PM
I bought mine straight from a Ford dealer who sells a lot of Ford motorsport parts. Name of the dealer here in Houston is Tommie Vaughn
Old 03-16-2010, 08:49 PM
750teryx 750teryx is offline
750teryx is starting off with a positive reputation.
what kind of mustang did yall buy them for....87-93?
Old 03-16-2010, 10:28 PM
yep, 87-93.
Old 03-17-2010, 06:19 AM
MBDiagMan's Avatar
MBDiagMan MBDiagMan is offline
MBDiagMan is gaining momentum as a positive member of FTE.
Shorties will indeed be fittable, but there will be minimal power gain. Exhaust all possibilities for finding small tube, full length headers before resorting to shorties. Full length headers will give you SIGNIFICANT torque gain throughout the rev range, from idle up.
Old 03-17-2010, 07:03 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
Call Sanderson, they can custom bend some headers to fit. They did a great job on the custom headers I needed to clear the rack & pinion and cable clutch on my Mustang.
1978 F100 2wd 400m headers? bcso290 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 07-02-2014 08:06 PM
73 F100 302 and ford shorty headers BigShelby 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-10-2013 09:59 PM
Do you have a 67-72 F100 429/460 w/headers? thesprocket26 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-07-2004 01:45 AM
Do you have a 67-72 429/460 w/headers? thesprocket26 Engine Swaps 1 06-28-2004 09:42 AM
Headers.. 73-79P/ULover Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 20 02-27-2004 07:39 PM
Tags
1977, 1978, 351, 351w, 7379, 78, f100, f150, fit, ford, headers, mustang, pickup, short, shorty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
