Junkyard Motors
Junkyard Motors
I am thinking about going to the junkyard and finding an efi truck with low miles. pulling it , make sure the bearings and everything are good and putting on a barb intake and 4 barrel carb and doing it that way. The reason for me wanting to do this is I do not have the money for all the machine work and everything. Does anyone see any problems in doing this?
I have never converted a 6 from efi to carb, but I have a v8, and it's not too bad. On a v8 you just change out the timing cover from the old engine to the efi engine along with the fuel pump eccentric on the camshaft gear, and the fuel pump will bolt right on.
I used to pick efi engines because they had the lowest mileage at the time. Now they are getting so old I don't know if there is really any point.
on
That was the logic I was thinking, but I was also along the same lines in that mileage might not be a concern anymore due to age. I would probably look for a wrecked truck first (probably there because of the wreck, not the engine), where a clean truck might be there because of the engine.
Sounds like we need a six cylinder expert. Hopefully they just put a cover on the efi block, and you could take the cover off and install the pushrod(if it has a pushrod?) and the fuel pump from the older engine.
While i understand the desire for low miles, 300-6's are well known to live happily past the 300K mark. with most of these trucks, its impossible to know the actual mileage, especially at a JY since the odometers only read to 5 places. you'll never know if it has 65K, 165K, or 465K miles. plus by staying with a carbed engine to start with, you're not immediately trying to go into swapping parts and getting things to match up. IIRC the intake and exhaust gaskets were not the same, i think the carbed had an extra hole. just my .02.
Yeah the reason I'm wanting to go with an efi motor is its newer and hopefully in better condition. I plan on dropping the pan and pulling the valve cover and head to make sure everything is in good working order. If I find a carbed motor that is in good working order I will use it but I was just wondering worst case senario.
Redneckfordf2502002
46
03-27-2014 12:15 PM
