Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Ontario Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
  #1 (permalink)
Old 01-13-2010, 07:58 PM
Headviking's Avatar
Headviking Headviking is offline
Garage is empty, add now
Headviking is gaining momentum as a positive member of FTE.
Post A great Diesel Tech Mechanic at a Dealership
I am having a great experience with a Ford Diesel Tech Mechanic. How would I spread the word. I had a extremely poor experience with another dealership Tech Mechanic as well. Where can I spread my experiences, without getting into trouble? All this in Southern Ontario. Toronto (GTA) area.
http://images.ford-trucks.com/forums.../party0023.gif
__________________
If your commin, your done. If your strocken, you've just started.
2007 F250 6.0L PSD Lariat 4X4 - Dieselsite Coolant bypass Filtation - Bilstein Shocks - Rough Country Duel Steering Stabilizer - Fumoto Oil Drain Valve - Blue fuel pressure upgrade spring - Water Separator Drain Plug Upgrade - ARP studded - Fuel Pressure, ECT, EOT, EGT Gauges - Scangauge ll - AutoEnginuity Scantool
  #2 (permalink)
Old 01-14-2010, 11:11 AM
loudfords's Avatar
loudfords loudfords is offline
1979 Ford F-150
loudfords has a good reputation on FTE.loudfords has a good reputation on FTE.
Right here is good! Post up the place of the good, and also post the name of avoid, but do NOT go into major detail, or repeatedly post about bad place, and that should keep everything good, I think.
__________________
Chad - loudfords - Ontario Chapter Leader
Click HERE to join the Ontario Chapter
1979 F150 351W
2003 Explorer XLT
  #3 (permalink)
Old 01-14-2010, 05:01 PM
Red Ford Truck's Avatar
Red Ford Truck Red Ford Truck is offline
Red Ford Truck is gaining momentum as a positive member of FTE.
Thumbs up Well if we are giving out KUDOs
I'll give a thumbs up to Moyens Ford in Lindsey, hands down the best dealership I've ever dealt with.
Ford dealerships in my area I did not like, marigold (one good experience, one bad experience) and fraser (two bad experiences)
We just took my wifes 2007 Ranger in because it's at 58,000 kms warranty is 60,000, there was a TSB for the Clutch slave cylinder they did that job and we asked them to do a synthetic oil change and check the truck over and rotate and re balance the tires.
With taxes $102.00
Plus it was a truly cold day when we dropped the truck off, they had the free loaner car warming up in the parking lot waiting for us.
Rick.
__________________
Red Ford Truck
  #4 (permalink)
Old 02-18-2010, 08:57 PM
Headviking's Avatar
Good experiance at Yorkdale Ford in Torornto (Mike Chan) is the tech guy to see.
Bad experiance at Kennedy Ford in Oakville.
Bad experiance at Oakland Ford in Oakville.
__________________
Tags
beachville, dealer, diesel, ford, forums, mechanic, mechanics, ontarioor, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
