2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Terrible brake pad wear (never seen this)
Old 01-22-2010, 10:38 AM
Blowinsmoke's Avatar
Blowinsmoke
Blowinsmoke is offline
I checked my pads on the rear of my 07 expedition. The top and bottom leading edges were worn on both the inner and out pads (both wheels).
The middle of the pad has most of the material left while the leading edges are almost gone.
Trying to post pics but hosting site not responding.
Any reasons why top and bottom edges are wearing like this. Is this common for rear disk brakes?
Old 01-22-2010, 10:43 AM
berry1234's Avatar
berry1234
berry1234 is offline
Do the pads look similar to this? http://www.autoextreme.co.uk/AutoSho...Blackstuff.jpg
If so, that is how they are designed. Post a pic of yours.
Old 01-22-2010, 11:06 AM
Blowinsmoke
Yes that is how they look. At what point do you change the pad if the leading edge is getting thin? By thin I would say 1/8 or so.
Old 01-22-2010, 11:12 AM
berry1234's Avatar
berry1234
I would go by the center thickness. If it is less than 1/8" or so replace. Don't forget to turn the rotors.
Old 01-22-2010, 11:15 AM
Blowinsmoke
Berry Thanks for your response. I have the truck on the lift. I took one side off for complete inspection and was getting ready to do the other.
On average how many miles are the pads expected with normal driving. I have almost 40,000.
Rear seems more worn than front.
Old 01-22-2010, 11:18 AM
berry1234's Avatar
berry1234
It all varies. Ford pads are typically softer and wear quicker. I have seen pads go in 20K and I have seen pads last over 100K. Measure your center thickness inside and out and let us know what you have.
