Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 01-13-2010, 05:34 PM
boyler boyler is offline
Garage is empty, add now
boyler is starting off with a positive reputation.
air in fuel lines f-250 7.3 diesel
Hi!
I've run out of fuel in my ford F250 7.3 diesel and now after refueling there is no posibility to start the engine.
Please tell me how to remove air from fuel lines properly.
I know that maybe this is silly and basic question but seriously I dont know how to do it. I was trying to find in this forum similiar thread but I didnt found.
thank you for any clues
  #2 (permalink)
Old 01-13-2010, 06:35 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
The pump has lost it's prime. There's a chance you've also sucked debris up into the screens in the mixing chamber, so you may need to drop the tank soon and either clean the screens or do the intank mods.
To answer your question, filling the tank more than half way helps. Sometimes filling the fuel filter bowl (and replacing the lid) and cycling the key will help. Don't waste the batteries trying to start. The fuel pump is electric so turn the key on and listen to the pump. It will come on for 25 seconds, then shut off. Just cycle the key on for 25 seconds, then off, then back on again. You'll be able to hear the change in sound of the pump when it's primed.
Other options would be to disconnect the fuel line from the back side of the pump, stick a short hose on the pump and dip the other end into a container of fuel. Cycle the key several times to prime the fuel lines, then reconnect the factory line and cycle the key several more times. You can also blow compressed air at about 20 psi into the tank through the fuel filler neck. Wrap a rag around the blow nozzle to help pressurize the tank some and cycle the key. Don't make an airtight seal and don't over pressurize the plastic tank.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #3 (permalink)
Old 01-17-2010, 09:02 PM
newfordy newfordy is offline
newfordy is starting off with a positive reputation.
Another thought/possibility
If you haven't solved the problem by now. Your problem might not be fuel related but oil. The hi-pressure oil pump resevoir may have run out by "priming" the fuel system. Resevoir is on top front center of engine. Oil level should be about 3/4 inch from top (remove plug to check).
__________________
, '01SuperCrew-5.4L-4X4-BrightRed-Gaylord's bedcap-
DeeZee steps-Bedrug--real "air horns"(train horns comming)-AAAAND
Eye like it!!
Tags
250, 73, air, diesel, f250, ford, fuel, gas, line, lines, prime, remove, run, running, start, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
