52 merc exhaust maninfolds fit 239 F-1?
They were $15.00. Look to be same bolt pattern, but exhaust exits at the back end of passenger side manifold instead out the bottom like on my truck. I think cross over connects between the manifolds on both fronts.( like a 292 Y block). On my truck the cross pipe runs straight out the lt side bottom and meets the other side in a Y. Not sure if this would conflict with the starter or if the crossover would hit something on the truck. Couldn't get the pics to save on here. Probally will put on some headers oneday, but just trying to get it a little quieter for now so I can start doing some resto work.
Thanks
Mitch
Thanks
Mitch
i'm confused, you said, 239 V8, do you mean Yblock?... typically, ford cars had the dual manifold set up...like thunderbirds, merc's etc ansd trucks had the crossover pipe...but not until after 53, as most had flatheads prior to that year...correct me if i'm wrong but didn't Yblocks come out in '54?,,,so, to answer your question yes car maniforlds will fit on the truck engine...but you might have a clearance issue with your steering box...better to find some rams horn headers, for your truck...but they are spendy and hard to come buy...
