TBC Fault - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
TBC Fault
Old 01-13-2010, 01:14 PM
wedge88 wedge88 is offline
wedge88 is starting off with a positive reputation.
TBC Fault
My truck was at the dealer for the last week because of coolant leak for the 3rd time. This time they finally proceeded to change head gasket. When I go to pick up the truck it has message stating TBC Fault. I know this is related to trailer brake controller so I go back into dealer and tell my service guy. He tells me it just came on and it is not related to anything they have done. I asked him to document that it was on when they gave it to me and heading home because we had something going on. I called today to talk to Tech and he says it just came on but it was not related to the engine repair they were doing so he couldn't do anything about it. They drove the truck over 100 miles and now this message is on and won't go off. They tell me I can bring it back in but it would be on my dime. Any ideas as to what this could be. If it is a loose wire then I will just take care of it because it is not worth the hassle. When they removed the cab could they have pinched a wire? Looking for any ideas on where to look.
Old 01-13-2010, 01:17 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Most often it is caused by water getting into and corroding the trailer socket in the back. First thing I would do is to just disconnect that harness, and see if the light goes out.
Old 01-13-2010, 01:26 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I had that happen on my 06 and it was the entire module that needed replaced. Just pulls out of the mount in the dash and a new one goes in its place.
Not hard to do but you really need to get the code cleared and see if it comes back.
Do as bpounds recommends and make sure
Old 01-13-2010, 01:47 PM
Will try this tonight. Thanks for the information. Anyone know a rough cost on a replacement. The unit has always been finicky with different trailers so I may just buy a new one and see if it works better. If not then I will return it or sell it.
Old 01-13-2010, 02:27 PM
bpounds's Avatar
2 bit Californian
Check with Ed at y2kford parts. I think your part number is 6C3Z2C006AA. But check with him to be certain. It should be around $220.
Old 01-13-2010, 03:06 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
Quote:
that the in dash module. list price $306.33 sell price check my web site.
if you wanted to add this function you would order 5C3Z19H332BA for diesels. it's a kit with master cly and module.
Old 01-13-2010, 03:37 PM
bpounds's Avatar
2 bit Californian
Ed, just for my edification, is the module the same for a diesel or gasser? I know the kit is different, but I assume that's because of the master cylinder. But I have not determined whether the module itself is identical.
Old 01-13-2010, 04:32 PM
Former Vendor
module is the same.
kits are diff for gas if dual or single rear rear.
and diesel uses another diff one.
Old 01-13-2010, 11:11 PM
Diesel-Fanatic's Avatar
Diesel-Fanatic Diesel-Fanatic is offline
Diesel-Fanatic is starting off with a positive reputation.
The dealer said they wouldnt fix it? Ok. Dude, they changed your head gaskets, meaning they had to pull off your entire cab to do so. Also Meaning they disconnected ALL of your electrical components and everything else... It was their fault, and you can get them in BIG TROUBLE for not fixing it. I would love to have been there with you on that one... I would be getting a new TBC before my truck even left the shop... So Call Dearborn Ford in michigan. They are over almost Every ford dealership and will kiss your *** over any problem. Tell them what the dealer said and im SURE whoever the mechanic is will get burned.
Old 03-05-2011, 07:56 AM
engine70 engine70 is offline
engine70 is starting off with a positive reputation.
2006 F350 Powerstroke 6.0-Showing TBC Fault. Original owner says he couldn't get the OEM in the dash TBC to work with his trailer so he added an aftermarket TBC (Prodigy P2). Will this cause the TBC fault and is there any way to permanently clear it?
TBC Fault Code help 2007 F250 SD Powerstroke blind180 1999 to 2016 Super Duty 13 11-14-2016 11:34 PM
Adding OEM trailer brake controller to a 2012 F250 XL BenKlink 1999 to 2016 Super Duty 0 08-17-2015 09:48 AM
TBC fault emmagator 6.0L Power Stroke Diesel 7 05-23-2013 04:02 PM
TBC Fault mnmwhit 6.0L Power Stroke Diesel 2 12-16-2012 02:56 PM
TBC Fault Code need help mrw1 1999 to 2016 Super Duty 1 01-01-2012 07:11 PM
Tags
2005, 2006, 60, brake, code, duty, f250, f350, fault, ford, super, tbc, tbf, trailer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
