CCV Mod from Donaldson
Saw this in a farm newspaper and thought it could be used for a CCV mod with some alterations. It would get rid of the oil smell and recover the oil. Since we don't have an oil return line from the turbo, could it be plumbed in to an open port on the block if there is one? I called for a price but have to go through a "certified distributor" so isn't available locally. This thing may be too big to fit easily where it would be able to drain into the oil pan. Just something to think about.
http://www.donaldson.com/en/exhaust/...ary/061798.pdf
Thats a pretty nice looking design. I built something similar, and based of the design Clux had origionally made. I just havent put mine into service yet haha. Using 2" pvc, capped at both ends. The feed goes about 2" up the tube, and the suction line directly off the top, and back into the intake. Then you stuff SS scouring pads inside. That catches most the oil, and then the air continues into the intake. Keeping the crank case still under vacuum. Then you would occaisionally have to open the drain in the bottom, to let the caught oil out. But it may prove to be a good idea to find a port in the block to drain it back into like they have done. If donaldson makes it, Im sure its a very very nice product.
That is an interesting alternative to the popular 4500 or 6000 Racor setup. Never seen that one before. Here is the setup I ended up going with:
Ford Truck Enthusiasts Forums - cavitation's Album: Closed system CCV re-route
Could you maybe do a T into the dipstick tube, or one of the valve covers? Of course, this would assume the coalesced oil is gravity driven as the pressure required to push the oil up may exceed the available maximum drive pressure from the incoming vapors...You may be able to make room around the 'dog house' and drain it into the valve cover. If not, some sort of fitting at the oil pan may work as well.
I've been wanting to build my own, and your homemade setup is top notch!!!
Pocket - Here is your build list. Let me know if you have any questions or would like a couple additional photos of anything.
Materials -
Item: Canister/Nylon T-Strainer
Company: McMaster-Carr
McMaster-Carr
Part #: 9875K221
Price: $29.27
Company: Industrial Specialties Mfg.
Item: Nylon 1.5 inch male to 1 inch female reducer (quantity 2)
Part #: NC-24-16 (Price $1.87 each)
Item: Nylon 1”x 1” straight male threaded (quantity 1)
Part #: N16MCB-16 (Price $1.12)
Item: Nylon 1”x 1” male barb 90 degree one end threaded elbow (quantity 1)
Part #: N16MEB-16 (Price $1.26)
Item: Nylon “1 x 1” male barb 90 degree elbow (quantity 1)
Part #: N16EUB-16 (Price $1.44)
Home Depot items
1” inside diameter straight brass barb, only need 1. (connects return hose to L shaped intake short rubber hose)
1” copper 90 degree copper fittings, only need 2. (one to connect reversed dog house to hose and one for return path route to connect to intake.)
Hose specs -
Approx 13 feet of 1” inside diameter rubber hose if mounting unit in the frame rail location I used. I used Gates Premo flex petroleum rated hose but Parker petroleum rated hose is good stuff as well. Don't use common heater hose.
Materials -
McMaster-Carr
Part #: 9875K221
Price: $29.27
Home Depot items
Hose specs -
Hey Nic, Do you know CAT's? I got a weird problem with my 420D at the moment. Will be working on it today but if the "dummy" fixes don't work, sure could use some knowledge......
