5.4 205 degree thermostat?
Old 01-13-2010, 07:27 AM
nitropolaris2's Avatar
nitropolaris2
nitropolaris2 is offline
does anyone know if someone makes a thermostat that is over 200 degrees for the 4.6/5.4?
Old 01-15-2010, 06:27 AM
torkum's Avatar
torkum
torkum is offline
Why would you want one that high?
Old 03-08-2010, 12:36 AM
RentAMan's Avatar
RentAMan
RentAMan is offline
Talking
Your a nut to put anything that high in these vehicles.
They call for about 180* in the modulars (they are aluminum).
You want to blow it up early, that is the way to go?
Old 03-08-2010, 06:45 AM
msgtord's Avatar
msgtord
msgtord is offline
The higher temp would give you a bit more fuel mileage around town under light load. Would not do it if towing, loss of power, and higher combustion temps could burn a piston.
Old 03-08-2010, 07:57 AM
redwood's Avatar
redwood
redwood is offline
If your engine is running too cool, thin out your antifreeze a bit. Too concentrated a mixture will affect heat transfer in the engine. If your cabin isn't warming up enough, you might need to replace your heater core. Unless you have a *specific* reason for wanting to do this, I wouldn't try to patch an existing problem by creating a new one.....
Old 03-08-2010, 04:47 PM
RentAMan's Avatar
RentAMan
RentAMan is offline
Talking
The newer computer controlled engines are not as forgiving as the older
ones. No matter what you do, the computer is going to try to compensate for the change. If its too far out of its parameters, you
will get all kinds of codes pop up and it will run like poop. Not to
mention that you are taking a chance on ruining your emissions system
and warp the aluminum heads, blow the radiator or whatever.
As mentioned earlier, fix what is wrong and keep your truck @ 180*,
as it was intended to be.
Anyway, we are curious as to why you want this?
You never did say.
Old 03-08-2010, 06:40 PM
redwood's Avatar
redwood
redwood is offline
Another thought about if you're running too cool, you could check your fan clutch. It could be locked up causing it to pull air all the time.......
Old 03-08-2010, 06:46 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
The OP hasn't visited this site since he posted his question.
He also posted it at another site and, when it was pointed out how bad the idea was, said he's way, way up north and needs more interior heat in the winter.
He was advised that a higher temp thermostat was the wrong thing to do and he never returned there, either.
Let this thread die and stay dead.
Raise
03-27-2017 01:11 AM
chipmunck
5.0L Coyote
10-10-2016 04:35 PM
69issofine
1983 - 2012 Ranger & B-Series
07-04-2015 07:48 AM
Steve
04-04-2006 11:46 PM
mrbeefcake
03-13-2003 09:15 AM
Quick Reply: 5.4 205 degree thermostat?
