Heater problems - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
Heater problems
Old 01-12-2010, 08:20 PM
Hammy321's Avatar
Hammy321 Hammy321 is offline
Hammy321 is starting off with a positive reputation.
Heater problems
My 09 F350 has had some heat and air problems and now the dealership is telling me that all fords do it and it is natural. Well I am wondering if anyone is having the same problems as I am. When my heat is on and set to a certain temp it will blow warm for a little bit and then get cold then get really hot. The truck is not set to auto so it should just blow at one temp. Also wile one side my be doing this when it is on duel the other side will have no temp change. I know of one other person that this is happening to but his problem is a little different. His vents and defrost will stay at a warm temp wile his floor vents blow cold. If you are having any of these problems or have herd of them let me know. Also if you have had none of these problems I would like to know also. The truck years that should be effected are 08, 09, and 10. Thank you for your help.
Lee
Old 01-18-2010, 08:18 AM
fordmasterdieseltech fordmasterdieseltech is offline
fordmasterdieseltech is starting off with a positive reputation.
first thing if it's a 6.4 check coolant level. as you know these things are common for radiator leaks and a low coolant level will give you these issues. post a vin and i will run an oasis and check for any known concerns
Heat AC Question 2011 E-350 ttles714 1968-2013 Full Size Vans 12 12-19-2013 06:30 PM
Right-hand defrost vent not blowing air? PatsPOS Excursion - King of SUVs 0 12-08-2009 09:23 PM
Intermittent heat RedDragon 1999 - 2003 7.3L Power Stroke Diesel 8 02-10-2009 08:52 PM
F & Rear A/C / Heat Ques - Am I stupid? QuadVan 1968-2013 Full Size Vans 15 01-16-2005 04:58 PM
Some vents blow cold, some warm scabbard 1997-2006 Expedition & Navigator 4 05-07-2004 09:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
f350, heater, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
