F1 vent window seal replacement - Ford Truck Enthusiasts Forums
Old 01-12-2010, 10:06 AM
Doraville's Avatar
Doraville Doraville is offline
Doraville is gaining momentum as a positive member of FTE.
I just spent the last hour searching the archives and reading everything I could find on the subject. I'm not getting the impression that it is possible to replace the vent window door/window seal without removing the center divider. I'm also getting the impression that removing (and reinstalling) the center divider is a major pain.
Any words of wisdom that you guys could impart before I tear into this would be greatly appreciated.
-DV
Old 01-12-2010, 11:24 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Well, you need to remove the wing from the frame to replace the seal. So if it's still installed in the truck, then the center bar comes out with the wings. I've read that some guys have problems withthe center removal, but I haven't done mine yet - so I'm not sure!
Old 01-12-2010, 12:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It's not that bad a job. Keep track of the order of special washers on the wing window lower pivot.
Old 01-12-2010, 08:23 PM
wheelie31's Avatar
wheelie31 wheelie31 is offline
wheelie31 is starting off with a positive reputation.
Its not a big deal i had my wing windows and center divider's out and back in the truck in 30 min its not hard, You will have to roll the window up or down to get the divider out of the inspection hole.
New Glass, New Seals and Felts...Woohoo Doc 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 08-17-2014 10:13 AM
Vent Window Removal Flathead 51 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 01-05-2011 06:30 PM
Vent window seals TBucketJack 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-21-2005 09:35 PM
Vent window seal installation problems svgearhead 1967 - 1972 F-100 & Larger F-Series Trucks 3 06-15-2004 08:44 AM
vent window seal replacement stangman67 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-08-2003 11:25 PM
Tags
1987, 1995, 51, f150, ford, removal, remove, replacement, seal, sindow, truck, vent, window, windows, wing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
