Is this basically a bolt on procedure - rearend for 54 F100
I got a 9" rearend out of a 1969-70 F100 to go in my basically stock 1954 F100. My understanding was it was a straightforward bolt on swap for the stock one I took out of it. Is that in fact the case? Anybody that can share a pic of how it attaches to the springs would be most appreciated. It's been a while since I took the other one out and I do not see it covered in my shop manual.
Any other tips/watchouts as I tackle this are welcome.
If the rear axle is like the one in the earlier '48-52 trucks you'll have to make shock mounts. I haven't done it yet but I've read all of the posts on how to do it. I have a page on my web site describing how MTflat did it in his Bonus Built truck:
Rear Axle Page
Rear Axle Page
I kind of hate to see this swap described as a "bolt-in", it really isn't (maybe on mid-fifties?). It's as close as you'll get, for sure. As Fergusonic points out, there's more to it. Figure $100 minimum for driveshaft mods and balancing alone, new spring plates are needed, the shock mounts can be a significant effort or cost, and you likely aren't going to slap on the "new" diff with old boneyard brakes, old axle seals, and old bearings (MT Flat got really lucky!). After all that you find out if the "new" unit was a noisy POS and needs a rebuild. I honestly wonder if it's really cheaper than having the stock diff rebuilt with new gears? I was quoted ~ $750 for a very thorough rebuild with new gears, new carrier, and all new diff bearings. It would be done in two days, too. Hmmmmm.....
Yes, definitely some things to think about. I got the rear springs installed today (had them rearched) and the rearend is ready to attach. I measured and it looks like it will bolt up okay. The rearend I found included the drums and the emergency brake cables are intact. I think it is in good shape but I wont know with certainty for a little while.
From a diagram I saw it looks like I need a bracket that the ubolt bolts to that fits underneath the axle after it is aligned with the spring. I did not see a part number for it but I can't see how I can attach without it since the newer axle is a bigger diameter than the old one and I cannot use it.
Most of the donor axles I've seen didn't use the bottom plate as the shock anchor.
DutchB100
01-14-2012 08:15 PM
palmercomputes
01-26-2007 08:50 AM
54Guy
01-19-2002 09:15 PM
