351m-c6 to aod - Ford Truck Enthusiasts Forums
351m-c6 to aod
Old 12-25-1999, 12:37 PM
Trail_Rider Trail_Rider is offline
Trail_Rider is starting off with a positive reputation.
351m-c6 to aod
Old 01-04-2000, 09:01 AM
frankie frankie is offline
frankie is starting off with a positive reputation.
351m-c6 to aod
i've got a 351m w/c6 in a 77 f100. from an earlier question, someone suggested changing to an early 80s tranny with aod. is this possible? will the 80s tranny w/aod bolt up to the 351m?
if so, are there any modification needed?
Old 01-04-2000, 09:54 AM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
351m-c6 to aod
As far as I know Aod trannys came out in the 80's and the 351m/400 was only produced a couple of years in the 80's until it was dropped. The only Possible donor I could think of is to find a later model 460 and see if you can find out if Ford ever mated an overdrive tranny to it since the 460 has the same bolt pattern. Somebody else on the forum should know some more about it than I do.
Old 01-04-2000, 10:29 AM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
351m-c6 to aod
Checking through Hollander interchange, I could not find any year in which a 460 came out with an over drive trans, except the E4OD, which is electronic and would not work for you. All of the AOD were for small block engines only
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old 01-04-2000, 10:58 AM
351m-c6 to aod
and the quick response. i've been told by a garage that there was no practical way to have an od in my truck. i might as well forget about it.
Old 01-05-2000, 02:25 PM
sam_1 sam_1 is offline
sam_1 is starting off with a positive reputation.
351m-c6 to aod
Someone makes a controller for the E4OD.
If you had that, a 460 E4OD should bolt up to your 351M.
Old 01-06-2000, 01:49 AM
V10 MAN V10 MAN is offline
V10 MAN is starting off with a positive reputation.
351m-c6 to aod
Jet a copy of Truckin mag. A company named JET has kits to use an OD tranny. Or jetchip.com
Old 01-06-2000, 06:25 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
351m-c6 to aod
V10, I just did a quick check at their site, their catalog starts at 86 and only for the 302. I don't believe that any help for this request is there.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old 01-06-2000, 11:23 AM
bc bc is offline
bc is starting off with a positive reputation.
351m-c6 to aod
I think you can do anything if you want to spend enough money. If it is true that the E4OD will bolt up to the 351m-400 then I think this site will be helpful.
<a href="http://www.baumannengineering.com">http://www.baumannengineering.com</a>
Old 01-06-2000, 12:23 PM
jowilker's Avatar
351m-c6 to aod
BC, You are quite correct in that anything can be done for enough money. The big problem with most of us here is we have champagne tastes, and beer budgets.
Thanks for the link.
John
66 F100s
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Tailgate mods 1978 - 1996 Big Bronco 6 05-25-2002 03:08 PM
Cams broom FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-24-2001 12:46 PM
Tags
351m, 400, 460, aod, bolt, bolting, boltup, c6, e4od, ford, trannys, trans, transmission, truck, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
