where to get a reman 4R100 - Ford Truck Enthusiasts Forums
Old 01-11-2010, 09:32 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
I would like some experianced opinions on where to purchase a decent reman/rebuilt trans.
I don't want to break the bank... would love a $4000 bullet proof trans, but Its just not in the budget right now.
A friend has almost 100k on his "Jasper" with no problems,(01 F350) and he does frequent heavy towing. I have never personally dealt with them or any other "big trans rebuid companys" so your opinion will be appreciated.
Thanks,
Old 01-11-2010, 09:34 PM
8tsixt 8tsixt is offline
8tsixt is gaining momentum as a positive member of FTE.
Most here will tell you to go with a BTS trans. Best of luck to you on your search.
Old 01-11-2010, 09:44 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
No matter what you do your going to spend about 3500-4000 for a tranny... What are you looking for and at what price range?
Old 01-11-2010, 09:49 PM
Franko72's Avatar
Molon Labe
Quote:
A stock trans. and under $2000 if possible...
Old 01-11-2010, 09:53 PM
CSIPSD's Avatar
Quote:
Junk yard my friend... Bet you can find one at a wrecking yard for about that, maybe a bit less with your core.
If you find one you will want to see it with the stock TC still attched to see if its burned the clutch disks, pull the drain and smell the fluid...
Not one out of a 2001...
Throw a valve body in and a new TC and you should be good.
Old 01-11-2010, 09:58 PM
Franko72's Avatar
Molon Labe
I have a new tc and flywheel, and have plans on a JW valve body, so that may be an option....Thanks for the help.
Old 01-11-2010, 10:23 PM
OTTOMATIC OTTOMATIC is offline
OTTOMATIC is starting off with a positive reputation.
Try here: BBB Review of Bill's Transmission in Panama City, FL
I have over 123,000 on one of his. They were highly recomended. They rebuild all the city and countys' ford trucks and buses.
Old 01-12-2010, 03:12 PM
aklim's Avatar
aklim aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
Problem is you have mods. If you get a tech like I know who makes it his life mission to tattle on anyone with mods on their truck, you might not be under warranty. Not saying it will happen every time but it could. You should be aware of that and probably plan on not having a warranty.
The only shops I know of are BTS and JW that don't care and don't car as much respectively. BTS doesn't care what you do. You break it, he fixes it. JW has either the Stage 1 for more than 350 or the Towmaster for less than 350HP. BTS will warranty it for as long as you own the trans and JW is limited to 2 or 3 yrs and 50K miles, IIRC. ATS used to say that unless you get a program that they approve of, you have no warranty. I heard it has changed but who knows.
I prefer to spend the money one time and not have to worry about it again. Is it cheaper in the long run? I think so.
Old 01-12-2010, 04:11 PM
rednekrebel28's Avatar
rednekrebel28 rednekrebel28 is offline
rednekrebel28 is starting off with a positive reputation.
I stumbled across this webstite last night. Might be worth checking into? Its awful cheap. See what you think, maybe give them a call and see if it has internals in it. lol
TRANS SPECIALTIES : Ford 4R100 Rebuilt Transmission Remanufactured and rebuilt automatic transmissions, transmission parts and torque converters
Old 01-12-2010, 06:01 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
That is for a gasser version of the 4r100. The Expedition in the description gave it away. While the gassers do utilize a 4r100 it will not bolt up to the 7.3 . I bet a diesel tranny would be higher.
Old 01-12-2010, 06:58 PM
Franko72's Avatar
Molon Labe
I guess I better start saving my pennies...
www.drivetrain.com seems to have the cheapest, But you get what you pay for im sure...
Old 01-12-2010, 07:17 PM
aklim's Avatar
It's only cheaper if it costs less in the long run. That is, unless you think the world ends in 2012. If you spend less now but more tomorrow, that is actually more expensive.
Old 01-12-2010, 07:27 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
you can't fix stupid!
indyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to behold
Quote:
i agree^^^^^^^^^^
bite the bullet and get the worry free trans. you wont regret it.....
Old 01-13-2010, 01:59 PM
dave at BD Power's Avatar
dave at BD Power dave at BD Power is offline
Former Vendor
dave at BD Power is gaining momentum as a positive member of FTE.dave at BD Power is gaining momentum as a positive member of FTE.
BD Diesel
Sure I can sell you a 4K transmission if you like but I also have other options available.
I have a stock build kit for around $600.00US, having a transmission shop rebuild your transmission with one of these kit may get you under 2K installed. The stock build is a Stage 1 and I have stage 2, 3 and 4 kits available as well. The stage 4 build is the same as our BD Performance transmission, but for half the price. Our BD Transmission build-it kits will save you the core charges and the expensive shipping fees as well.
Hope this helps
Dave
Old 01-13-2010, 05:56 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Buy the "good" parts and do it yourself.
You'll come in under $2K.
Pop
where to get a remanned motor and trans Preuett 1987 - 1996 F150 & Larger F-Series Trucks 21 01-15-2016 10:40 PM
Remans: Rep or Rap? Tugly 1999 - 2003 7.3L Power Stroke Diesel 66 11-01-2015 07:31 PM
opinions on this reman trans f1002692 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-19-2015 12:31 PM
Ford reman HD4R100? Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 43 04-19-2013 05:30 PM
Need a remanufactured 4r70w whos the best? 85camaroman 1987 - 1996 F150 & Larger F-Series Trucks 4 05-04-2008 10:01 PM
Tags
03, 2003, 350hp, 4r100, core, expedition, f350, ford, jasper, michigan, rebuild, reman, trans, transmission, wtb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
