How much does it cost to rebuild and engine? - Ford Truck Enthusiasts Forums
Old 01-11-2010, 05:23 PM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
I gotta customer that wants me to pull his '97 7.3, replace the rings (probably blew them using EITHER to start it) and then reinstall it. SO- aside from parts and fluids, what's the usual labor charge for something of this magnitude? Anybody know how long it takes to tear everything apart and pull the block? I normally charge $30 an hour, so I don't want to over or worse under charge the guy!
Old 01-11-2010, 05:39 PM
jcrammell's Avatar
jcrammell jcrammell is offline
jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.
$30 an hour is cheap. Stealerships are running $75.00 an hour and most mechanics that I know here are charging from $45 to $65 an hour.
Old 01-11-2010, 05:44 PM
mongo75's Avatar
And that's why I only charge $30. I'd rather do 10 hours of work for $300, than 3 hours of work at $75 for $225. Plus already having a full time job, if I don't get work I'm not dying. PLUS, I'm a glutton for punishment, I enjoy getting greasy LOL!
Old 01-11-2010, 06:47 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Danny, I'd confirm this first, but why don't you subscribe to alldatadiy.com ? There a sponsor here and for a pretty cheap price you get access to the full Ford service manual. I'm pretty sure it also gives you labor time as well. I think Pete (F250_) has a subscription. Maybe he can verify the labor time being included in the subscription.
Sounds like you're getting some side work. Having access to labor would be useful.
Old 01-11-2010, 06:52 PM
mongo75's Avatar
I got access to labor- my outta work buddy LOL! I figure I'd split the $$ with him- it's better to have something than nothing, and help him out at the same time.
Old 01-11-2010, 07:12 PM
F350-6's Avatar
Quote:
Lima Oscar Lima. By labor, I meant book time the mechanics charge. AllData is one of the services the pro's use to fix and charge customers. The DIY version is the same info, it just is cheap since it only covers one vehicle.
Old 01-11-2010, 07:26 PM
mongo75's Avatar
OH, hehe- I got all data at the base hobby shop. I can use that then!
Old 01-11-2010, 08:07 PM
Tecman's Avatar
Tecman Tecman is offline
Tecman is gaining momentum as a positive member of FTE.Tecman is gaining momentum as a positive member of FTE.
Quote:
Dang, thats actually cheap too! My dealer is at $102/hr!
Old 01-11-2010, 08:49 PM
mongo75's Avatar
Yeah my stealership is $96 an hr
Old 01-11-2010, 09:44 PM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod has a good reputation on FTE.kirkharrod has a good reputation on FTE.
Ever heard the saying "No good deed goes unpunished."?
That's the first thing that came to my mind...
Old 01-11-2010, 09:46 PM
kirkharrod's Avatar
Same here PLUS mine has unqualified mechanics!
Old 01-11-2010, 10:05 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
I usually "flat rate" the jobs I do for my friend's water well service. I use his shop and tools (except when I need specialty stuff). His employees do the cleaning for me and he has a hot water pressure washer. I figure "per hour" time at $35. We do anything from brake jobs, clutch jobs, trans & gear box rebuilds, to engine overhauls and hydraulic & pneumatic system fabrication on his service and well drilling equipment. I am usually involved in all his mechanical projects and advice.
Old 01-11-2010, 10:42 PM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
To R/R (Remove/Replace) and 7.3 is 24 hours book time. This doesn't include anything you do once the engine is out. I would probably charge for about 30 hours..
Alternator charging post faulty? handyandy123 6.0L Power Stroke Diesel 12 06-06-2014 09:17 PM
alternator charging post faulty? handyandy123 Excursion - King of SUVs 0 06-06-2014 09:14 AM
F450 charge air cooler removal for cleaning jinxie 1999 to 2016 Super Duty 9 05-06-2014 08:24 PM
Dealer Service Tactic - adding DEF Champ198 6.7L Power Stroke Diesel 37 08-13-2011 01:04 PM
Rear main seal Xwarrior86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 02-05-2011 11:29 AM
Tags
50, 54l, 73, 73l, 99, charge, cost, diesel, engine, ford, motor, powerstroke, rebuild, rebuilt, shop, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
