Whats This Noise????
Well i have an automatic 99 f-250 and i just noticed that when i get to s stop and then go again i hear a little clunk coming from the back and then kind of a little jurk forward.. I dosent do it all the time. Does anybody know what might be casueing this?
Also how offten do you guys change your oil?
had this same problem you described on chev p/u and it ended up being the rear brakes sticking, I replaced the slide pins and the pads and that took card of it.
There is also the possibility that it could be in the rear end but in my experience it would be really noticable going from reverse to drive and vice versa.
What he said. Start with the easy fixes first. Chock your wheels to keep it from rolling, remove the boot and grease up the slip joint. Pretty common. If that doesn't fix it then start looking at your brakes, remaining drive line, diffs.
Well, that's a broad question. You other was answered, but this will get you lot's of different opinions. I change mine every 7K, but I am using Syn. oil and Blackstone says I can go more, but 7K is good for me. When using dyno oil, I would change it every 4-5k. Some running extra filtration systems are going 10k or more on an oil change.
