GPR LED installed
GPR LED installed
So I just installed the GPR LED to indicate when the GP's are receiving power.....but I couldn't figure out a good place to mount the LED in my dash. Currently, it's just zip-tied to my brake controller until I figure out a permanent location. I would like to be able to easily see it when I turn the truck on without leaning/stretching to see around the steering wheel.
So......I'm interested in knowing where people installed theirs and if they like it or would rather have it somewhere else. Any feedback is appreciated!
Thanks,
-Chris
Thanks,
-Chris
Not sure I'm right on this one but splicing it in to the wait to start light would give you what your already getting on the dash, from a cold start that WTS light will only be on for 30 seconds or so, what the PCM commands. By hooking it up to the GPR, your getting a true reading on how long your GPR is actually staying on and using that to your advantage to get those glow plugs hot to warm the cylinder, thats the whole purpose for the LED mod.
I figured Doug was suggesting to use the extra wire from the GPR's output stud through the cab and to the wire that powers the WTS light (not sure if it's 12V or something different), which would then do the same thing as the extra external LED.
I'm thinking I'll either attempt to put it next to the factory gauges as Chris suggested or I'll wait until I decide to add gauges (EGT, trans temp, and one other.....)
-Chris
-Chris
For those wishing to use the WTS lamp in the instrument panel as an indicator for the GPR's output, that lamp is activated by a ground out of the PCM on pin 70 of the PCM, a black/pink wire. At least that's for my 2000. Other years might be different pins and colors.
That means that you're going to have to change a switched +12 volts into a switched ground to satisfy the WTS lamp's wire instead of the PCM. A 12-volt relay will do that nicely for you.
Pop
Pop
For those wishing to use the WTS lamp in the instrument panel as an indicator for the GPR's output, that lamp is activated by a ground out of the PCM on pin 70 of the PCM, a black/pink wire. At least that's for my 2000. Other years might be different pins mand colors.
Pop
Pop
I'm just askin... Why would you want to do that, the whole point of the GPR Led is to know when the glow plugs are getting juice, if you put it on the PCM output, all you know is the pcm is asking the gpr to close.
