1996 F150 REAR END
Old 02-07-2012, 07:25 AM
muddman150's Avatar
muddman150
muddman150 is offline
my 96 f150 rear end is slipping every time i take off hard.... so i went and put limited slip oil in the rear end.... it's still slipping any ideas what i should do?
Old 02-07-2012, 08:34 AM
deljac's Avatar
deljac
deljac is offline
Originally Posted by darthice
if it came as a 4x4 it should be a Limited Slip Rearend check your axle code in the door jamb and decode it to see if it is a LS rearend before you spend money on another one
is this true because my 2 that were wrecked and my current 2 4x4s are all 3.55 open. if its true man i dont have anyluck getting a LS
Old 02-07-2012, 08:48 AM
bashby's Avatar
bashby
bashby is offline
2 year old thread.
Muddman, If you have a limited slip rear you may need to rebuild it. There is an axle code on the doorjamb that you can post here and someone will decode it for you, or do a google search.
Deljac, not all 4x4's are limited slip, I'd say more like 25% or so, just my guess
Old 02-07-2012, 09:29 AM
andym's Avatar
andym
andym is offline
First, welcome to FTE.
Second, you should start your own thread rather than bring up an old one. It confuses people.
Third, despite its name, there is nothing to slip in the rear end every time you take off. If you're driving in a straight line, there is no slipping happening at all. There can't be because there are gears in the rear end that turn the wheels.
Your slipping is coming from somewhere else, probably your transmission. We also need to know the particulars of your truck. Year, model, engine, transmission, miles, symptoms, recent repairs, etc.
1996jkk
09-17-2016 08:50 PM
Digdigdug
05-15-2016 03:07 PM
1996f1502wdlongbox
12-01-2015 09:43 AM
FordYoungGun35
23
08-24-2012 11:13 PM
FordFriend150
21
04-16-2009 10:10 PM
Quick Reply: 1996 F150 REAR END
