P0171, P0174, P0430 on 1998 Explorer - Ford Truck Enthusiasts Forums
Old 01-11-2010, 09:19 AM
BoilerUp216 BoilerUp216 is offline
BoilerUp216 is starting off with a positive reputation.
I have these codes up for system too lean, bank 1 and 2, and 430: catalytic system below standard. My Explorer is rough idleing in the morning, or even stalling out. Once I accelerate or after a few moments, the rough idle is gone and the car rides great.
I suspect water is condensing/mixing in the gas line. I used Carb Cleaner to check all over the top of the engine for vacuum leaks and found NONE!
I've treated the fuel tank with sea foam to try and fix the water problem in the gas, but it isn't a solution.
Any ideas?
Old 01-11-2010, 01:23 PM
scucci's Avatar
scucci scucci is offline
scucci is starting off with a positive reputation.
Sounds like intake manifold gaskets.
Old 01-11-2010, 01:27 PM
Thanks Scucci. I am going to clean the MAF sensor/inspect it and look there. I appreciate it. If you think of anything else- I'm all ears.
Old 01-11-2010, 01:51 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Intake manifold gaskets are one common issue for a lean condition contributing to a rough idle. I'd also suggest you consider the Differential Pressure Feedback EGR (DPFE) sensor as another common issue on the Explorer that could cause symptoms and codes such as you describe. Whatever the issue, you want to remedy it as soon as possible to hopefully avoid more costly damage to your catalytic converters.
-Rod
Old 01-11-2010, 09:48 PM
cmaupin's Avatar
cmaupin cmaupin is offline
cmaupin is starting off with a positive reputation.
so should the intake be removed and gasket installed?, it could not be a sensor? thanks
Old 01-11-2010, 10:51 PM
shorod's Avatar
It could be either the intake manifold gasket, the intake air tubing between the MAF and the throttle body, or the DPFE. I'd start by checking for a vacuum leak and if you don't find one, start with the DPFE.
-Rod
Old 01-11-2010, 11:49 PM
wjbentley wjbentley is offline
wjbentley is starting off with a positive reputation.
I also have the same P0171 code. Was driving to a friends house an hour and a half away this past weekend and the truck drove perfectly fine until I got there. Weirdest thing for it to happen so sudden. Since then it's been idling rough, hesitates when I accelerate, some pinging and generally running poor. I replaced the fuel filter and air filter and it ran a bit better but still far from perfect. I have a 98 Explorer with 4.0L v6. Any ideas?
Old 01-12-2010, 12:39 AM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
Pinging and rough idle, i'm willing to bet you got a bug on your MAF sensor. remove it and clean it off.
Old 01-12-2010, 07:42 AM
cmaupin's Avatar
If you think you have some power loss I would look into the plugs, poss replacement.
Old 01-12-2010, 07:47 AM
shorod's Avatar
Quote:
If there's a bug on the MAF you also need to figure out how it got past the air filter and remedy that. WJBentley, you wouldn't happen to be running an aftermarket reusable air filter, would you? You also need to make sure the intake air tubing didn't fall off and that some vacuum line didn't crack or come off. Since you only have a code for one bank lean I'm suspecting more of a vacuum line or intake manifold gasket. An issue with the MAF or intake air tubing would likely trigger a code for lean on both banks.
-Rod
Old 01-12-2010, 08:03 AM
Are the intake manifold gaskets difficult to replace or if I choose to have someone else do it is it expensive? I'm a novice at this.
Old 01-12-2010, 08:59 AM
Could it be clogged fuel injectors?
Old 01-12-2010, 10:40 PM
Turns out the plug in the number 6 cylinder was bad. It was burned out so bad the firing points on the top of the plug were burned off. Hope it didn't get in the cylinder and damage the engine. I also had fuel injection treatment done. Runs like a champ! Thanks to everyone who posted a reply. You all did truly help me.
Explorer P2104 & P2112 Help jfish1288 Explorer, Sport Trac, Mountaineer & Aviator 3 12-21-2015 10:32 AM
Bitten by p0174. Need help chev2ford 1997 - 2003 F150 19 10-24-2014 11:31 PM
93 f150 to 98 explorer engine help? 79highboy150 1987 - 1996 F150 & Larger F-Series Trucks 9 07-22-2012 11:59 AM
05 5.4 3 v idle rough and nocking brain1988 2004 - 2008 F150 7 09-23-2011 11:43 AM
idling rough CEL codes P0300 and P1443 jamest1969 Ranger & B-Series 3 02-26-2010 08:28 AM
Tags
1997, 1998, 2000, 98, 99, code, explorer, ford, idle, mountaineer, p0171, p0171p0174, p0174, p0430, po171, rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
