302 swap in 79 F150 4x4 - Ford Truck Enthusiasts Forums
Old 01-10-2010, 11:15 PM
82ford302's Avatar
82ford302 82ford302 is offline
82ford302 is starting off with a positive reputation.
just recently aquired a 79 f150 4x4 that originally had a 300 I6 and 4 speed in it. well the 6 cylinder engine was removed but the transmission and transfercase is still in the truck. i know the 302/351W motors will bolt to the transmission.
but my questions are:
1) what motor mounts or frame perches would i need to put the 302 in there?
2) what flywheel and clutch combination would i have to use since the 302 is from a 86 lincoln continental with the 50oz balance crank?
thanks for the help guys.
Old 01-11-2010, 01:42 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
dont waste your time on the 302. drop another 300-6 in there. its an awsome motor and more suited for a 4wd truck. not to mention you wont have to change a thing.
the 302 was never offered in that truck so either making custom frame mounts or trying to make 2wd frame mounts work could be a chore. then exhaust will need changed, radiator will need changed etc..
Old 01-11-2010, 01:55 PM
82ford302's Avatar
thanks man thats what i needed to know. guess i'll go on the hunt for another inline 6
Old 01-11-2010, 02:33 PM
right on, you will be much happier
check out cliffordperformance.com, fordsix.com for great build ideas regarding this motor.
Old 01-11-2010, 07:00 PM
82ford302's Avatar
cool deal. thanks for the links
Old 01-13-2010, 09:49 AM
mudder460's Avatar
mudder460 mudder460 is offline
mudder460 is gaining momentum as a positive member of FTE.
Well, yes 302's were offered in these trucks, but the 351w wasn't. I have a 300 in mine right now and it is a good motor, I am swapping to a 351w in the future cause I am building a play toy. I wouldn't suggest a 302, the 300 has less HP but around the same TQ, and the 351w has more of both. You can use 302 motor mounts on the 302/351, and you would need to get the motor purches from a 4x4 that had a 351m/400 in it. As for the clutch, you can run whatever you want.
Old 01-13-2010, 12:41 PM
the 302 was not offered in a 4wd ford during these years accept for maybe the F100 model and early broncos. so i am not sure where your getting that info (not trying to be rude). if you saw one it was probably a transplant. also the motor purches from a 351m/400 wont work for a 302/351w due to the blocks being different.
you will only find 300-6, 351m and 400's. Thats it for the 78-79 model years. prior to that from 73-77.5 you got those along with 360 & 390's being offered but again no 302 or 351w. i know because i owned a 73.
Old 01-14-2010, 11:06 AM
mudder460's Avatar
Hmmmmm, I could have sworn a 302 was available in the 4x4's, wouldn't be the first time I have been wrong (ask my wife)! I remember a guy doing a swap that went from a 351m to a 351w and he used the same perches. The best bet would to be to seach in here and in the 73-79 section.
Old 01-14-2010, 11:40 AM
and we all know Ford does odd combos sometimes also. i think all wifes are like that, honestly i would rather be wrong because there is less accountability/responsibility ya know LOL
I need to know if I can use my t19 4 speed transmission with a fuel injected 302. 81bullnose 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 01-05-2017 06:40 PM
81 f150 4x4 302 v8 Kayla McDonald 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 06-13-2016 10:34 PM
79 f150 engine swap 79sb4x4 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-17-2013 11:04 AM
86 302 in a 79 f150 custom...how hard? jpeckham 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-19-2012 11:51 AM
302 vs 351M postalxj 1973 - 1979 F-100 & Larger F-Series Trucks 47 08-06-2009 07:09 PM
Tags
302, 35x125x15, 390, 4x4, 77, c6, continental, engine, f150, ford, good, headers, motor, mounts, transmissions, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
