2007 Navigation radio question
Jay
Thanks. I will check that as soon as I can. Might be a few days... I was hoping someone had a real "procedure" so I don't brick it! I thought that they were both the same, but am wondering if the '06 LT had some fancy lighting dimming or something. I will reply with results either way. Oh, since an e-bay radio, not sure on the color. The seller said the lighting worked, and wondered why it wasn't also. But, you never know...
It is black, but doesn't say either when powered up...
I did do the 3 and 6 key preset button check last night, and have some interesting results, but, was not able to find where it would scroll down to the "illumination" screen for any changes. Arrggg, so close! But, I did find all of this:
Button 1 - self test - fail B1342ECU and B2477 Config
Button 2 - DTCS found the above two and B1318BAT L
Button 3 - Signal 56/7
Button 4 - Soft levels - Main: 00_2D_0, CDSP: 01_04_0, CD: 24_40_0 and SDR: 00_00_0
Button 5 - Display test - YAAAYYY it works.. all buttons illuminated and then black... arrggggg
Button 6 - No Config - all Configs 1-6=0, with 7L3T 18C8 15EG at the front
So... at least I know all the lights are getting power. Now, I do have the GROM audio MP3/Ipod/Aux adapter installed into the changer 16pin port, and it always has power. So, that may be keeping me from getting to the appropriate menu. Or, I'm missing a button stroke somewhere. That may be for this weekend if so!
Thanks!
Thanks!
GROM (the aux input box maker) suggested I remove their unit and retry the procedure. No luck. Is there a way to clear the errors? Maybe that is causing the radio to not let a config. change be made. While aggravating, it works, just dark. Now more of a puzzle, which makes you want to solve it even more! Maybe I need to send it somewhere for a reprogram?
deshet1980
05-24-2017 04:13 PM
angeldiaz215
2004 - 2008 F150
03-24-2016 09:59 PM
JimmyInDenver
09-03-2013 04:13 PM
LAJones
08-18-2007 12:15 PM
