What type of coolant to add? - Ford Truck Enthusiasts Forums
Old 01-10-2010, 04:31 PM
tperk100's Avatar
tperk100 tperk100 is offline
tperk100 is starting off with a positive reputation.
At 60K miles on my 04 6.0 TD F350, my factory coolant is a little low, and I cannot figure out what type of coolant to add. I drew some out to try to tell the color, but its faded and I would only be guessing at the color.
Any help will be appreciated.
Old 01-10-2010, 04:33 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Its called ford premium gold, its actually gold colored (looks like PEE lol)
Just remember when topping off, the MIN line on the jug is the new MAX line. Do not fill it above the MIN line!
Old 01-10-2010, 04:41 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
You can also use Zerex GO-5 sold at Napa for 10.99 a gal. for concentrate or 50/50. Same stuff as the Ford Premium Gold.
Old 01-10-2010, 04:48 PM
tperk100's Avatar
Thanks Guys! I guess I cannot use the PROLINE ORANGE I bought at Pep Boys.
Next Question....at what interval does the fluid need to be completely changed out? I though it was 100K miles but now I am confused.
Thanks again.
Old 01-10-2010, 05:17 PM
69cj's Avatar
Thanks again.
5 years or 105,000 miles whichever comes 1st. Ford recommends flushing system with VC-9 iron cleaner 1st and then with distilled water 4 or 5 times prior to filling with a 50/50 mix.
Old 01-10-2010, 05:39 PM
69cj's Avatar
<!-- / icon and title --><!-- message -->
<!-- BEGIN TEMPLATE: ad_showthread_firstpost_start --><!-- END TEMPLATE: ad_showthread_firstpost_start -->Just finished flushing the cooling system doing it the Ford recommended way as per post by cheezit and the 6.0 mechanic at the local dealer. Cost break down as listed;
2 qts. of motorcraft Iron Cleaner and 1 T-stat "O" ring = $63.73
4 gal. Zerex GO-5 coolant from Napa = $45.63
10 - 2 1/2 gallons containers of distilled water = $20.00
Total = $129.36
Ran the iron cleaner with distilled water thru the system for a 20 mile freeway drive. Came home, drained and removed t-stat and flushed 5 times with distilled water. Water coming out at the end of the 5th flush looked as good as the water going in. Installed T-stat with new "O" ring and added 3 3/4 gal. coolant. This is a little extra to compensate for the coolant filter which I installed a new filter after the flushes. Drained 1st thru rad. petcock, then lower rad. hose and then left block plug. Repeated this procedure 5 times. Hope this helps anyone contemplating doing their own coolant flush. Local dealer couldn't answer whether they used distilled or tap water so decided to do it myself. Glad I did. Now I can R&R the air filter in about 10 minutes. Piece of cake once you have a procedure. Doing the flush the way I did it will take most of a day so do not attempt it if you are in a hurry.
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->__________________
"05 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_5_0>F-250</NOBR>, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
<!-- / sig -->
I did this a couple months ago, thought it might help.
Old 01-10-2010, 06:29 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
I would recommend installing a coolant filter after you flush out the system. Can save you problems down the road. Well worth the money and easy install.
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
Old 01-10-2010, 07:35 PM
69cj's Avatar
I agree 1,000% with the above.
Old 01-12-2010, 12:19 AM
tperk100's Avatar
OK...you guys have convinced me to flush, change fluid, and install coolant filter.
I have looked for the post by cheezit with detailed instructions but have not been able to find it. Could someone give me a link to it?
Since my Oil Guard bypass takes up the space next to the passenger side battery, I am planning on ordering the frame mounted coolant filter kit. Any comments on this?
Thanks
Tom P in Va Beach, VA
2004 F350 6.0 TD
Old 01-12-2010, 02:11 AM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
check out the tech folder I believe it has been moved to their. along with the coolant filter install.
Old 01-12-2010, 12:27 PM
rocky1074's Avatar
Thanks
2004 F350 6.0 TD
I found this hope it helps!! I did mine without removing the T-stat. Just let it heat up to temp in between flushes so T-stat opens and leave heater on to flush out heater also.
4 gal. Zerex GO-5 coolant from Nappa = $45.63
15-gallons containers of distilled water = $15.00
Total = $125.36
Old 01-12-2010, 12:48 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.
Thanks
2004 F350 6.0 TD
Tom, another spot could be behind the grille attached to the core support. Check out my albums to see where I positioned my oil bypass. I'm just down in Moyock, if you ever want to get together to compare notes, give me a shout at powerstrokediesel@embarqmail.com , Tom W.
Old 01-12-2010, 05:06 PM
69cj's Avatar
Total = $125.36
Gee, I wonder where you found this.
Old 01-13-2010, 02:50 AM
03-6L-X's Avatar
03-6L-X 03-6L-X is offline
03-6L-X has a good reputation on FTE.03-6L-X has a good reputation on FTE.
Thanks
2004 F350 6.0 TD
Go to here for detailed instructions. Any questions, let us know.
http://www.ford-trucks.com/forums/90...nge-101-a.html
<!-- / message --><!-- sig -->
Coolant type by color? Lx460 6.0L Power Stroke Diesel 4 08-30-2013 02:34 PM
Should I flush my coolant? landscapeguy 6.0L Power Stroke Diesel 9 06-23-2013 05:41 PM
ANY NSECRETS TO REPLACING MY COOLANT StanleyZ 6.4L Power Stroke Diesel 8 11-07-2012 01:01 PM
F 450 coolant change stan'37 1999 to 2016 Super Duty 3 08-27-2012 07:11 PM
Coolant tolliewolly 6.0L Power Stroke Diesel 9 10-25-2010 12:07 PM
Tags
2003, 2005, 2006, 60, 60l, coolant, coolent, f150, f250, f350, factory, ford, go5, kind, type, zerex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
