A/C & heater vacuum line problems - Ford Truck Enthusiasts Forums
Old 01-10-2010, 03:51 PM
jennkent5454 jennkent5454 is offline
jennkent5454 is starting off with a positive reputation.
2003 f150 5.4l Fx4---
I am wondering if the black vacuum line that runs from near the battery through the fire wall, across the top of the A/C, is the one that controls the direction of the air flow from floor, defrost, or panel?
Mine blowing in defrost only so I'm guessing it's a vaccum line?
Old 01-20-2010, 10:01 PM
EDIT: SEE POST BELOW THIS ONE
This is the Vacuum Connector End View—Electronic Automatic Temperature Control
1. NOT USED
2. RED-PANEL/DEFROST DOOR
3. BLUE-PANEL/FLOOR DOOR
4. BLACK-SOURCE VACUUM
5. WHITE-AIR INLET DOOR
6. YELLOW-PANEL/FLOOR DOOR
Old 01-20-2010, 11:01 PM
THIS MAY ALSO HELP
Old 01-25-2010, 09:00 PM
IT IS FINALLY FIXED!!!!!!
I changed the 4 o rings inside the EATC or head unit. $2 for parts.
I followed these instructions!!!!
Repaired my EATC module today. - MercuryMarauder.net Forums
thanks JACook
Old 01-25-2010, 10:47 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
thanks for the update. always heard that was an expensive repair. sounds like its pretty cheap if you take the time to dig in. wonder if the manual system has o-rings between the ports ???
Old 01-26-2010, 01:46 PM
GalvYank GalvYank is offline
GalvYank is starting off with a positive reputation.
I'm going to check to see if this is what's causing my automatic climate control to not blow at all, unless it feels like it. Thanks for the info.
A/C will blow through all vents but front ones... WTF fixed this problem months ago its back! Varro 1999 to 2016 Super Duty 4 09-15-2016 05:24 PM
A/C switches to defrost when 4X4 is engaged, ESOF 2005 F250 lakewood 1999 to 2016 Super Duty 2 04-13-2015 08:52 PM
AC blows through defrost only 99-exp 5.4 99exp4wd5.4l Expedition & Navigator 5 06-16-2012 05:52 AM
Vacuum lines off heater/vent/defrost control knob FLJ Cooling, Heating, Ventilation & A/C 0 05-15-2009 09:19 PM
Ideas for tracking vacuum leak? Pocket 1999 - 2003 7.3L Power Stroke Diesel 12 07-04-2008 05:19 PM
Tags
04, 1997, 1999, 2003, ac, air, conditioer, controls, f150, ford, heater, hoses, line, lines, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
