76 F100 4x4 Single speed transfer case. any info.
Your transfer case is a Dana 21. It is gear driven. You can swap an early Bronco 2 speed Dana 20 transfer case very easily. If you want to swap to a 203 or 205, I would pick the 205 with a 4 speed to make the swap easy. Your existing 4 speed would need to have the output shaft changed in it to accomodate 205 anyways.
66with352
09-07-2016 10:52 PM
FixinOlBlackie
11-08-2013 10:02 AM
bigcrunch
06-19-2013 11:33 PM
mudding4life
07-28-2006 05:19 PM
msmyth
09-03-1999 07:20 PM
1966, 21, 76, case, dana, f100, ford, guide, identification, model, pictures, rebuilding, single, speed, transfer, transfercase, transmission
