08 F250 Went into Limp Mode - ideas?
Drove down to the store this morning - everything normal. Got back in the truck and it wouldn't start at first. After 4 times, it fired up and it immediately displayed the WRENCH in the drivers information center. So, it is in limp mode. Stayed that way all the way home.
Ideas as to what this means, the fix required, etc?
so it starts better now though? as normally would?
You could try to disconnect both batteries, wait 15 mins and re-connect and see if that does something to reset it.
But this may be something else, if you have the time, might want to just have the dealer put the computer on it and read the fault code.
Disconnected batteries for a little while then hooked both back up and restarted the truck. Started without a problem, but is still showing the dreaded WRENCH in the display. Will have to take it to the dealership tomorrow. It has just over 30k miles on it, so still under warranty. I also have an extended warranty on it, so hopefully they can at least get me in a rental if they have to keep the truck for repair.
Tech at local dealership ran the code and it was the fuel pump. He tried a temporary repair but it did not work. Had to order new fuel pump. Since it was already after 5:00 p.m., they won't have one in until Wednesday. Dealership gave me a loaner car at no cost. I can't complain about how they treated me, but am concerned seeing how many fuel pumps have gone out on these trucks at low miles. Mine has just over 30k miles.
