Best glow plugs - Ford Truck Enthusiasts Forums
Best glow plugs
Old 01-09-2010, 08:02 PM
ebaugh90's Avatar
ebaugh90 ebaugh90 is offline
ebaugh90 is starting off with a positive reputation.
Best glow plugs
Ive been having alot of trouble starting my truck, at first we thought it was the batteries or my starter. Come to find out its most likely my glow plugs. I was wondering what the best glowplugs would be for my truck. 1994 F-250 7.3 IDI N/A.
Also, ever since its gotten really cold, my fuel mileage has gone down the drain, i used to get around 22mpg, now im getting around 16. Is it the cold, or could it be my glow plugs causing the problem too, since it takes about 10 minutes to start my truck in 30* weather.
Old 01-09-2010, 08:09 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
Mororcraft beru plugs.
GP's are not hurting your mileage but we all tend to idle them more and the winter blend fuel has less btu's so you get less mileage.
Old 01-09-2010, 08:13 PM
ebaugh90's Avatar
thanks for the help man. I was wondering, cuz i dont black smoke as much anymore. Probably cuz of the different mix of fuel. Yeah im testing my GPs tomorrow. My buddy whos got a 99 f350 said my GPs were causing my starting problem. So we'll test them tomorrow.
Old 01-09-2010, 08:19 PM
ebaugh90's Avatar
Where can i find the Mororcraft beru glow plugs, ill try my advanced auto parts tomorrow or something.
Old 01-09-2010, 08:52 PM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
rmalottwtes30 is gaining momentum as a positive member of FTE.
You can get them from ford, or you can search online. There are places you can get them for $9.99 each.
Old 01-09-2010, 09:10 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
agree.
your looking for motorcraft glow plugs part #ZD-9 for your 7.3l(their made in Germany by Beru)
p.s. not sure how your going to test them but the test light method is not the best.it can find the totally dead ones,but can't find the ones with too high of resistance like a good meter will.just fyi.
Old 01-09-2010, 10:07 PM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
I've always tested mine with a multi meter and always found the dead ones without a problem. Worked on checking them on Ford 6.9, Isuzu 2.2 and VW 1.6.
Old 01-09-2010, 10:18 PM
yeah i found the two dead ones no problem.but the other 6 that lite up with the test light still where not good enough.i didnt have a meter that could read ohms this low,so i just replaced the other 6 (cheaper than buying a meter that would) and she fires up like it should.i do read this is quite rare tho,to have them lite up still,and not be good enough.
Old 01-10-2010, 08:11 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Old 01-10-2010, 11:09 AM
WarOzz's Avatar
WarOzz WarOzz is offline
WarOzz is gaining momentum as a positive member of FTE.
I got mine at Shucks/O'rielly for 11.49 and they had them in stock. My favorite local shop had them for 10.99 but was out of stock. You can save a bit by purchasing online but you will lose it in the shipping... not to mention waiting for them. They seem like a pretty common part for most parts houses to carry.
Cold start issue SGorman13 1999 - 2003 7.3L Power Stroke Diesel 30 02-26-2014 06:26 AM
white smoke on crank ? Glow plug? Guzzo 6.0L Power Stroke Diesel 8 12-08-2013 01:46 PM
Time for new glow plugs? six6six 1994.5 - 1997 7.3L Power Stroke Diesel 14 11-14-2011 08:27 AM
hard cold start (glow plugs work fine) tpolley Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 32 12-09-2009 10:47 PM
Glow plug broke in engine Kestas 1994.5 - 1997 7.3L Power Stroke Diesel 30 01-22-2008 02:53 PM
Tags
2002, 69, 73, 73idi, beru, diesel, f250, f350, ford, glow, international, liter, plug, plugs, powerstroke, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
