Battery Location - Ford Truck Enthusiasts Forums
Battery Location
Old 01-09-2010, 01:35 PM
lm987 lm987 is offline
lm987 is gaining momentum as a positive member of FTE.
Battery Location
Greetings,
I have a 1950 F-1 that I just put a 302 in. The new headers will not allow the battery to be placed in the original battery box and location. There is not suffiecient room on the firewall either.
Any suggestions???
Thanks
Old 01-09-2010, 01:50 PM
dongc1's Avatar
dongc1 dongc1 is offline
dongc1 is starting off with a positive reputation.
I used a sealed Exide Orbital battery behind the seat. I put a black cover over it and it looks good. The ranger seat just clears it when the seat is all the way back.
Old 01-09-2010, 01:57 PM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
1. Behind / in-between the seats with a sealed type (like a no name Optima)
2. In the box in a box.
3. Some kind of frame drop down like the FAT FENDER people use.
Old 01-09-2010, 04:20 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
On my 49 I recessed the battery into the bed floor.
Bobby
Old 01-09-2010, 04:44 PM
HD74's Avatar
HD74 HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
I'm relocating mine under the passenger side and behind the tranny crossmember. I'm going to use a drop down battery box and sell for about $130.
Old 01-10-2010, 02:04 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Why will it not fit on the firewall? Upper passenger side just under the hood?
Like this:
Name:  IE Sept 20  Engine Compartment Front.jpg
Old 01-10-2010, 11:14 AM
Battery Location
Thanks to all that replied. Inow have some ideas.
Thanks again.
lm987
Old 01-11-2010, 11:31 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Quote:
Originally Posted by lm987 View Post
Greetings,
Thanks
I can't imagine headers which might impact a battery box on the firewall. You may not be able to use the original battery box but there should be ample space to mount the battery on the firewall. I'm using a 302 in my 49 F-1 and that's where mine is going...
Old 01-11-2010, 09:05 PM
F-1 battery location
Thanks for your reply. The headers impact it on the left side where the original battery and battery box were located. I tried on the right side firewall but it interferes with my heater hoses. I already have the heater located and don't want to cut new holes in the firewall and firewall cover. I think I will go with a drop down battery box and locate it on the right side frame just behind the rear transmission mount.
Thanks again.
Old 01-11-2010, 09:54 PM
Rokcrln Rokcrln is offline
Rokcrln has a good reputation on FTE.Rokcrln has a good reputation on FTE.
Here is another easy to get to location. Fender hides it and with a simple rubber mud flat in front of it you can not see it and it will also keep some of the road grime off of it. And with the tire turned left it can come out or you just pull the tire every 5-8yrs for a new one if needed.
Kevin
LFD Inc.
Old 01-12-2010, 12:13 AM
Hmmm! If your heater tubes come out of the firewall in the original locations, you should have just barely enough room to put the battery box above them - like 3/4 inch. It's tight, but do-able. The top of my battery is about 3/4 inch below my hood when closed. But it fits.
Here's another picture and shows the heater hoses:
Name:  Engine Wire Looms.jpg
Old 01-12-2010, 09:04 AM
My picture isn't as good as Julie's but this one clearly shows the heater hoses under the battery box. This is my other truck which is running a SBC...
Old 01-12-2010, 11:27 AM
Mines a BBF (FE 390) and I don't see how it could get much tighter in there than it is.
Old 01-12-2010, 05:43 PM
bobbytnm's Avatar
I agree, there is tons of room on the firewall. I have a 500ci Caddy in my 49 and there is plenty of room on the passenger side upper firewall for a battery.
I removed the heater hoses. I'll probably run them through the side of the cab to keep things clean (when and if I install a heater). Once I get my fuel injection up andrunning I'll get rid of the fuel filter on the firewall as well.
Bobby
Old 01-12-2010, 10:26 PM
F-1 Battery Location
Hey...
Thanks to all for your pictures and ideas. I need try a smaller battery box and see if it will fit on the right firewall.
Thank again.
lm987
Battery Box Options bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 03-19-2016 02:53 PM
Battery location question Jmanb13 1968-2013 Full Size Vans 1 01-23-2016 11:50 AM
Battery saver relay replacement DJRAAL 1999 to 2016 Super Duty 0 09-22-2014 12:45 PM
Battery saver relay location slomafarms 1997 - 2003 F150 3 10-31-2011 11:59 AM
Auxiliary battery JoePa2 1968-2013 Full Size Vans 2 10-21-2011 11:34 AM
Tags
album, battery, booklets, box, cca, cd, chopper, drop, ford, location, mkx, mud, resume, truck, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
