crew cab shorty
on
There's a User here with a very similar name to that photobucket username...
Here, hang on a minute.
He hangs around here...
Here is a link to his profile:
https://www.ford-trucks.com/forums/member.php?u=152959
You need the WheelBase of a ShortBed StyleSide CrewCab?
(If it exist, I will try and get those for you...)
Welcome to FTE, By The Way.
This is the best site on the www.
My name is Anthony, I hope you get answers to any future questions you may have...
Ford Truck Enthusiasts Forums - View Profile: mando jake
on
1 Post
You wouldnt happen to be the guy that emailed me about the crew on a supercab would you?
None the less i can help ouy here. The Wheelbase on that truck is 133" same as a regular cab longbed. The crewcab longbed wheelbase is 167" and the crewcab shortbed wheelbase is 150". So it you have a shortbed you need to cut 17" out of the bed and if you have a longbed you need to cut 34" out of the bed. Make a cut about 2" from the front of the bed then cut out what is need and weld the front of the bed back on. Thats what im doing to mine. Here is a better side shot of a crew done the same way. Just not a high quality job.
on
These are the 1976 factory specs...
Shortbed Crew Cab...
F-250 Crew Cabs had a wheelbase of 150" with 6.5' beds, the same short bed as any other pickup of the line.
Long Bed Crew Cab...
F-350 Crew Cabs had a wheelbase of 166.5" with 8' beds, the same long bed as any othe pickup of the line.
hope this helps
hope this helps
