tsb 09-23-01 radiator leaks
on
<TABLE border=3 cellSpacing=0 cellPadding=3 width="96%"><TBODY><TR><TD bgColor=#0000ff colSpan=2>[************]Printable View (69 KB)[/COLOR] </TD></TR><TR><TD class=VERTCENT bg*************** width="25%" align=middle>TSB
09-23-1
</TD><TD class=VERTCENT bg*************** width="65%" align=left>
<TABLE border=0><TBODY><TR><TD width=230>FORD:
</TD><TD>2008-2010 F-Super Duty</TD></TR></TBODY></TABLE>
ISSUE:
Some 2008-2010 F-Super Duty vehicles built on or before 9/14/2009 and equipped with a 6.4L diesel engine may exhibit repeat radiator leaks due to malfunctioning (hyper-extended) high temperature thermostats.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH align=middle>OPERATION</TH><TH align=middle>DESCRIPTION</TH><TH align=middle>TIME</TH></TR><TR><TD class=NOBOTTOMBORDER align=left>092301A</TD><TD class=NOBOTTOMBORDER align=left>2008-2010 F-Super Duty 6.4L: Pressure Test Cooling System, Road Test, Monitor PIDS, Replace The Radiator (Do Not Use With Any Other Labor Operations)</TD><TD class=NOBOTTOMBORDER align=left>3.0 Hrs.</TD><TR><TD class=NOBORDER align=left>092301B</TD><TD class=NOBORDER align=left>2008-2010 F-Super Duty 6.4L: Pressure Test Cooling System, Road Test, Monitor PIDS, Replace The Radiator, And Thermostats (Do Not Use With Any Other Labor Operations)</TD><TD class=NOBORDER align=left>3.8 Hrs.</TD></TR></TBODY></TABLE>
DEALER CODING
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH align=middle>BASIC PART NO.</TH><TH align=middle>CONDITION CODE</TH></TR><TR><TD class=NOBOTTOMBORDER align=middle>8575</TD><TD class=NOBOTTOMBORDER align=middle>42</TD></TR></TBODY></TABLE>
<HR>NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2009 Ford Motor Company
******** language=JavaScript src="/renderers/utils/logging_omniture.js">*********>
09-23-1
- 6.4L DIESEL ENGINES - REPEAT RADIATOR LEAK - BUILT ON OR BEFORE 9/14/2009
ISSUE:
ACTION:
SERVICE PROCEDURE
- Verify the coolant leak is from the radiator, refer to pin point test (PPT) A found in the Workshop Manual (WSM), Section 303-03.
- Verify the venturi tee is installed.
- If installed, confirm it is installed correctly (note - orientation direction on part). Refer to applicable Field Service Action (FSA) for vehicle built on or before 5/15/2008.
- If not installed, install per applicable FSA on vehicles built on or before 5/15/2008.
- Prepare the vehicle for a test drive.
- If the coolant leak at the radiator is large enough to cause an unsafe test drive or potential for engine/vehicle damage, proceed to Step 5.
- Before driving the vehicle confirm the coolant level is at minimum level or above in the degas bottle. If required add 50/50 mix to coolant bottle.
- Test Drive - use an Integrated Diagnostic System (IDS) or equivalent and monitor engine oil temperature (EOT) and engine coolant temperature (ECT) parameter identifiers (PIDS).
- With EOT at 195 °F (91 °C) drive on the highway unloaded at 55-70 MPH (89-113 Km/h) constant speed to observe EOT and ECT temp.
- Test results/next steps:
- If EOT is less than 8 °F (4.4 °C) higher than ECT, and the coolant temp fluctuates roughly 5 °F (2.7 °C) - the thermostats are okay and do not need to be replaced. Replace just the radiator. Refer to WSM, Section 303-03 (Engine Cooling).
- If EOT exceeds ECT by greater than 8 °F (4.4 °C) or if the ECT readings fluctuate 10 to 12 °F (5.55-6.66 °C) roughly every 30 seconds - replace both thermostats and radiator. Refer to WSM, Section 303-03 (Engine Cooling).
- If vehicle is not drivable and the coolant leak is found to be from the radiator, remove and replace both thermostats and radiator. Refer to WSM, Section 303-03 for both radiator and thermostat removal procedure and approved cooling system draining, filling and bleeding procedures.
WARRANTY STATUS:
DEALER CODING
senix
6.4L Power Stroke Diesel
01-20-2012 03:24 PM
senix
25
04-01-2011 07:19 PM
perryg114
09-30-2010 05:18 PM
