Front main seal 2002 - Ford Truck Enthusiasts Forums
Old 01-08-2010, 06:30 PM
rangerrick63 rangerrick63 is offline
rangerrick63 is starting off with a positive reputation.
It appears that I have developed a leak at the front main seal on my 02 7.3L.
It looks like it should not be too tough of a job, if my eyes are not failing me. I wanted to get some input on the job though...
I see a few bolts directly behind the balancer, is this a bolt on seal housing?
I've also seen that there is a front main seal installer tool. Is this really necessary to replace a seal that is in a removeable housing? I've seen these type of seals before, & all that is needed is a simple seal driver. Just wanting to make sure I don't get into a job that is going to require a "special tool" just to be able to complete it... <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old 01-08-2010, 06:50 PM
rtazz17's Avatar
rtazz17 rtazz17 is offline
rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.
Are you positive its the front main seal and not the hpop or a fuel bowl/line leak?
Old 01-08-2010, 06:58 PM
makomaker's Avatar
makomaker makomaker is offline
makomaker is gaining momentum as a positive member of FTE.makomaker is gaining momentum as a positive member of FTE.
correction, is it the oil pan or the front cover...either one i believe, the engine needs to come out
Old 01-08-2010, 07:56 PM
KMUL's Avatar
KMUL KMUL is offline
KMUL is starting off with a positive reputation.
My advice, and I can't believe I'm saying this, but take it to the dealership and let them do it. I also have an '02 which I bot about a year ago, front main started leaking not long after I bot it. They only charged me about $200 to replace it.
Unless you just really want to tackle it yourself. I didn't have the time to mess with it and that seemed kind of cheap considering the effort I would have to put into it.
Your situation and expertise is obviously different...
Good luck!
Old 01-08-2010, 09:37 PM
I plan on getting under it tomorrow with a can of break clean, a few rags, & make daam sure it's the front seal. With what I saw this afternoon, it really looks to be the front seal, but now that I read thru these posts...I definitely want to take a better look.
It went from zero leak to dripping pretty steady in one day, I mean, I have had no drips or any other signs on the drive-way, & today, I have many "dollar size" puddles...
I forgot that there are oil lines on top of the engine...could I be so lucky as it to just be an o-ring?
Thanks again for the advice...
Old 01-09-2010, 03:02 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Is this it bro, cause it looks like we are having the same issue
Old 01-09-2010, 06:08 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
i would replace the CPS oring first..its cheap and the cause of most of these leaks...also make sure the cover to the HPOP gear bolt isnt leaking..that will also fall onto the crank...it will be found behind the EBPS..
Old 01-09-2010, 06:46 AM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
Ranger, If I recall the front crank seal is installed in the housing that holds the Low Pres Oil Pump. you have to disassemble the the oil pump to repair it. I would just by a new oil pump. comes complete with cover, gasket etc. just remove old-install new. about $60 from Ed or Melling has one out that is supposed to be slightly higher volume.
I think the NAPA one is a Melling also.
Its been a couple of years but this is a straight forward job. do it from underneath and you don't even have to pull the fan. I don't remember if you need a crank pulley puller or not. somebody on here will chime in with the info we need
Barney
Old 01-09-2010, 08:05 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
I have a spare oil pump brand new in the box, let me know if you would like it
Old 01-09-2010, 08:52 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Quote:
Great offer Kris. Reps sent.
Old 01-09-2010, 08:59 AM
It's nice & sunny here this morning, still cold, so I'm going to have a cup of coffee...or two...
Then I'm going to go out & clean up the oil off the bottom to see exactly where it's leaking.
I do hope it's just an o-ring, but if it turns out to be the front seal, I will definitely look into the whole oil pump replacement.
Thanks to all for the advice & input...I'm really liking this site
Old 01-09-2010, 09:37 AM
bfife's Avatar
Yeh, its a great site. Some of the brothers know alot, some of us not so much. But we're all friends here and there is no such thing as a stupid question. Welcome to the 7.3 Brotherhood!
Barney
Old 01-09-2010, 10:05 AM
PaysonPSD's Avatar
rangerrick63,
Here's some LPOP info: LPOP PDF in case that is where the leak is.
Old 01-09-2010, 03:45 PM
Well I checked it out...It is definitely leaking from the front seal. Oddly, it doesn't seem to leak with the engine running, but after I shut it down, & it sat for a while, it started to leak...go figure.
Thanks again for the input, & especially thanks for the PDF...that was a big help. I suppose I'll be tackling that this week...
Old 01-09-2010, 07:02 PM
PaysonPSD's Avatar
Seems as though you and Brian (ChunderDown Under) have a very similar problem. LINK
New Member Annoucement - ersatz sddesigns New Jersey Chapter 1 04-20-2010 06:58 PM
New Member Annoucement - DOConnor88 sddesigns New Jersey Chapter 4 04-14-2010 01:57 PM
New Member Annoucement - grady1981 sddesigns New Jersey Chapter 2 04-14-2010 01:55 PM
Caliper hanging up...can I test them? MoyockPowerstroke 1999 to 2016 Super Duty 1 11-03-2009 06:02 AM
'09 Forest Green Color Pics Fleetsuper Excursion - King of SUVs 3 05-06-2009 01:34 PM
Tags
02, 2002, 2003, 73l, crank, est, f150, f350, ford, front, main, powerstroke, replace, seal, time, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
