6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Coolant Diagram
Old 01-08-2010, 04:26 PM
koboss1's Avatar
koboss1
koboss1 is offline
Coolant Diagram
Anybody have a diagram of the coolant system and where the thermostat sits
thanks
koboss
Old 01-08-2010, 06:25 PM
Hardrock_F250's Avatar
Hardrock_F250
Hardrock_F250 is offline
Is this what you want?
Old 01-08-2010, 06:50 PM
69cj's Avatar
69cj
69cj is offline
thanks
koboss
Follow the top radiator hose to the engine. That is where the t-stat is. Remove the air cleaner and top radiator hose. Remove 2 ten mm nuts and pry pressure sensor bracket off of studs. It is tight but will move. Remove 2 more ten mm nuts and the t-stat and t-stat housing lifts off of the studs. Use a new O ring when re-installing. about 5 bucks at dealer. This is for a 6.0 but I think they would be the same.
Old 01-08-2010, 07:00 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
here is more for you as well at this link: http://www.backglass.org/duncan/ps64...ing_system.pdf
Old 01-08-2010, 07:53 PM
cheezit's Avatar
cheezit
cheezit is offline
not even close to the same. ya have fun with that job. not a dyi project unless you have a day to do it. it pays about 3 hours to do under warranty.
Old 01-09-2010, 09:52 PM
fordtech08's Avatar
fordtech08
fordtech08 is offline
there are 2 t-stats on a 6.4 and I agree the job sucks
Old 01-10-2010, 09:43 AM
69cj's Avatar
69cj
69cj is offline
What's the reasoning behind 2 t -stats?
Old 01-10-2010, 10:10 AM
fordtech08's Avatar
fordtech08
they are different temps I believe so you get different amounts of flow, I gave up trying to figure out why ford does stuff a long time ago
Old 08-13-2017, 11:30 AM
Consumer Advocate's Avatar
Consumer Advocate
Consumer Advocate is offline
Lessons after 9 years
changing the thermostats really is not that difficult of a job. Many try to make it much more complicated than it needs to be. To access it the easiest way possible, remove the driver side battery, the degas bottle with the battery tray and you have nearly direct access to the tstat fasteners. once the clamp plate is loose, turn the top slightly to the front of the engine to pass over the hump in the housing and it comes right off. Then simply pop the housing off, replace the tstats and seals and reassemble. You do not need to loosen or remove the EGR cooler or loosen the radiator and support.... none of that pain in the backside stuff.
Old 08-13-2017, 04:58 PM
Picton's Avatar
Picton
Picton is offline
Good info there.
koboss1
40
12-27-2023 08:28 AM
Renegade3064
1999 to 2016 Super Duty
03-07-2022 02:25 AM
koboss1
22
02-19-2018 02:39 PM
RP27G8G
Modular V8 (4.6L, 5.4L)
13
03-18-2017 11:14 PM
WEagle
03-18-2017 05:54 PM
Quick Reply: Coolant Diagram
