Hard fault... Whats it mean?
I have a 94 <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_0_0>Ranger</NOBR> V6 4.0L that is going through about a tank every two days. Only codes that were there was a
157- MAF sensor went below 0.4 volts during the last 80 warm-up cycles. AND
998- Hard Fault present.
Whats this mean exactly? Any help with these will be greatly appreciated.
Well, a 998 code could mean you are not running the key off key on test correctly. That might explain why it a "hard Fault" rather than a component failure. Take a look at a web site called "the ranger station". Look under their tech section. There is also a tip on cleaning the throttle body.
76-high-boy
26
12-02-2011 06:38 PM
1868pike1978
07-20-2010 01:44 PM
