95 F-150 engine and transmission wire diagram
Old 01-08-2010, 12:01 PM
ComputerGeek2600's Avatar
ComputerGeek2600
ComputerGeek2600 is offline
I have a 90 F150 pickup with a engine that came out of a 95 f-150 pickup and a transmission that came out of a 97 f150. The problem is it's having some trouble staying in overdrive (or as some say lockup) at cruising speed. It would go in to overdrive when its under some kind of load but jump out when when its not.
Also, if you punch it, it wants to stay in the current gear until you let off. Like from a stand still, it will stay in 1st until you let off some and will quickly pass 6000 rpm if you're not careful.
So, we need some diagrams for the engine and transmission wire harness. Where might I find them?
Old 01-08-2010, 12:56 PM
Big-old-460's Avatar
Big-old-460
Big-old-460 is offline
i have a chiltons manual , i can look it up and scan the pages you need ... humm what do you need ? it might have it it might not ?
also is it manual or auto ? and for what yr 97 or 90 ?
just let me know as soon as possible ..
jayson
Old 01-08-2010, 03:59 PM
ComputerGeek2600
its an '97 automatic tranny bolted to a '95 302 V8 5.0.
Old 01-08-2010, 04:01 PM
subford's Avatar
subford
subford is offline
Sounds like the speed information is not getting to the computer.
You need a 95 cluster and wiring to go with the 95 computer.
I am guessing that you are using the 95 PCM and engine wiring harness.
Is it a 4R70W or a E4OD transmission?
Old 01-08-2010, 04:16 PM
Big-old-460
well i got the book on wireing just not sure what pages to scan for you... will just genral electic wireing diagram work ?
Old 01-08-2010, 04:36 PM
ComputerGeek2600
well, we just need diagrams on the engine wiring harness and tranny. mainly about how the computer communicates with the engine and tranny.
I'm not sure, it's a small transmission.
Old 01-08-2010, 05:30 PM
subford's Avatar
subford
subford is offline
Not sure what year computer and engine compartment harness you have?
Old 01-08-2010, 05:56 PM
ComputerGeek2600
engine wiring is 95, computer is 95.
Old 01-08-2010, 06:09 PM
subford's Avatar
subford
subford is offline
Email me and I will see what I can find.
Old 01-08-2010, 06:14 PM
ComputerGeek2600
Eh? Why? Why not just post it here or pm me?
Old 01-08-2010, 06:33 PM
subford's Avatar
subford
subford is offline
It would be to large and I can not post a PDF.
email address below.
Old 01-08-2010, 07:49 PM
ComputerGeek2600
i sent you an email...
Old 01-08-2010, 10:26 PM
ComputerGeek2600
thanks a ton. it should help us track down the problem.
theclaus11
19
09-26-2017 09:40 AM
Transam461
09-10-2016 12:58 PM
Blueranger91
08-01-2016 09:24 AM
Robsal
06-22-2016 04:09 PM
351Cleveland C4
25
04-28-2012 06:52 PM
Quick Reply: 95 F-150 engine and transmission wire diagram
